Ron (guest)
Guest
Posts: n/a
Hi evereybody , I am installing new front fuel pump on my 1989 930 turbo and just want make sure that wire connection is at the right place red on + side and brown on negative side , is it right thank you in advance
This post was auto-generated based upon a question asked on our tech article page here:
Old 03-31-2015, 11:38 AM
That is typically the proper connection, however I would just verify with a volt meter: when the red lead of the meter is connected to the red wire from the car and the black lead from the meter is connected to the B- terminal, crank the engine. The volt meter should display battery voltage. That proves that the red wire is the positive connection to the pump.
- Casey
