Mr9146's Avatar
Racing Seat Fitment Question
Does anyone know if the side-mount brackets for a Recaro Pole Position will work with a Momo, Sparco, or OMP seat without modification to either the seat or the bracket?
Thanks in advance.
Old 04-03-2015, 03:35 PM
disband
juanbenae's Avatar
generally one of the hole sets is elongated so from what ive seen they are pretty interchangeable.
Old 04-03-2015, 03:37 PM
Mr9146's Avatar
I appreciate the response.
Basically what I'm doing is putting my 914/6 back together. I have a Momo seat out of my racecar, and Patrick Motorsports makes a pair of side mount brackets for Recaro Pole Positions that allow them to bolt to the factory 914 sliders and tip bracket.
It would be ideal if the side mounts that Patrick Motorsports makes would work on my free Momo without modification. However, even if I have to slot the holes a little bit that would be fine, I guess.....
http://www.patrickmotorsports.com/part/recaro-seat-mount-bracket-set-to-914/
Old 04-03-2015, 03:43 PM
Racer
winders's Avatar
Even if the brackets fit the holes in the Momo seat, is the Momo seat the same width as the Recaro seat? I imagine the holes in the brackets that mount to the 914 slider line up only if the seat is the correct width.
Scott Winders
PCA GT3 #3
2021 & 2022 PCA GT3 National Champion
2021 & 2022 PCA West Coast Series GT3 Champion
Old 04-03-2015, 04:45 PM
Mr9146's Avatar
That's a good point. I'd like to believe they are the same, but I don't really know for sure.
However, I am not above making spacers to take up the missing width or slightly bending them outward if the MoMo is wider.
Old 04-03-2015, 05:27 PM
jittsl's Avatar
I'm almost certain that Recaro, Momo and Sparco all use the same front to back dimension on their mounting holes (you can almost certainly prove this by searching the manufacturers sites and looking for dimensioned drawings). Width will vary amongst them but I've used spacers between the bracket and the seat to accommodate narrower seats, I've also elongated bottom mount holes to widen the spacing when needed.
Laurence
1998 Specbox racer / 1998 Boxster / 1984 RSR tribute
1970 911E Coupe / 1970 911E "speedster" / 1969 912 Targa
1963 356B T6 Coupe / 1962 356B T6 Cabriolet
Current projects - 1955 356 pre-a Speedster / 1964 356C
Old 04-04-2015, 02:07 PM
