-   -   clink, clink, clink, CLANK! (http://forums.pelicanparts.com/porsche-911-technical-forum/859289-clink-clink-clink-clank.html)
SCadaddle 04-05-2015 09:42 AM
82SC. Sounds like something in the exhaust system is giving me a garbled metal on metal resonation noise when cold and during warm-up but then sounds fine. After driving and up to full temp (190-200F) and then shutting it down the exhaust system goes through the cool down clink, clink, clink, clink then a single loud CLANK! sound. Thinking maybe the accordions in the cross over pipe? Anybody have a clue where to look for typical contraction/expansion binds in the system? Not a dilivar head stud issue as that has been resolved with steel studs. Thanks.
tirwin 04-05-2015 11:03 AM
What is your exhaust setup? Sounds like stock heat exchangers. Cat and stock muffler?
A couple of ideas... Just spitballing...
Metal straps holding the muffler?
The heat shield around the cat?
Exhaust stud?
SCadaddle 04-05-2015 01:36 PM
Stock exhaust with the exception of a gutted cat. Leaning towards a M&K Euro Pre-muffler if it would be more quiet than the gutted cat.
Bob Kontak 04-05-2015 02:14 PM
I like Tirwin's thinking. Loosen the muffler straps a little to make sure you can.
Drive it like an idiot for a bit and then bring it into garage. Take the weight off the muffler just a smidgeon with a floor jack and loosen the straps again see if noise repeats when cooling.
It may be something silly like the shrouds around the header pipes. Just put a wee bit (I am talking tiny bit with a 2 X 4) of floor jack pressure on them after a drive and listen to isolate.
Ronnie's.930 04-05-2015 02:50 PM
Bob can relate to the thread title; he hears the exact same sounds each time he turns his head!!!
jason2guy 04-05-2015 03:05 PM
make sure its not a chain tensioner going south. ive had 2 pressure fed tensioners fail, one just last week.
stormcrow 04-05-2015 07:08 PM
Could be loose tensioner. I just pulled my engine and pulled the covers - the tensioner on the drivers side was slack by about 1/4".
So that could be what's going on - the chain could be slapping against the engine housing.
