-   -   Window mechanism (http://forums.pelicanparts.com/porsche-911-technical-forum/859408-window-mechanism.html)
JSV798 04-06-2015 06:29 AM
Window mechanism
Can anyone tell me whether a window mechanism with part no. 911 542 003 43 is for lefthand or righthand windowhttp://forums.pelicanparts.com/uploa...1428326905.jpg
universeman 04-06-2015 07:25 AM
Picture looks like passenger to me. The arms go towards the back of the car. Assuming the mounting on this part is from the visible side (which I think it is) you are looking at a passenger window mech.
JSV798 04-06-2015 09:47 AM
So you mean right hand? I'm based in the UK and here cars are right hand drive.
DRACO A5OG 04-06-2015 11:28 AM
Yes, right hand.
The motor faces forward and the spring faces inside the cab.
If I may suggest, please update your location so we will know you are across the pond :D Cheers!
JSV798 04-06-2015 01:56 PM
OK, I've put in my location and a car image - I'll add a few more when I can find them.
I thought it was a right hand door mechanism, just wanted to be sure as this is one I bought for my car but found it would require the door to be modified so didn't use it. In the end I repaired the original - needed some welding (I think the car was broken into by forcing the window down before my ownership)
Now plan to sell this mechanism. Many thanks for your help.
