tunnel fuel line length
Hi,
first off, yup, used the search function (haha), tons of great advice, but didn't find the length of the through tunnel fuel lines, anyone happen to know what it would be?
'74 911 ('73 RSR "tribute") - Backdate project that sort of went off the deep end.
http://forums.pelicanparts.com/porsche-911-technical-forum/996223-bergos-1974-911-backdate.html
Old 04-06-2015, 08:30 AM
Contact BoxsterGT.........
Len Cummings aka BoxsterGT is the fuel hose master. He's the guy you want to ask.
Tony
Old 04-06-2015, 09:21 AM
I just measured the lines i removed from my 82 SC recently. The polyamid tunnel lines are 67" long each including the metal end fittings. That does not include the rubber lines at the front. Not sure what year your car is. 82 tunnel lines terminate into metal lines from rear bulkhead into wngine bay. 67" is for the tunnel lines only. Probably means the tunnel itself is ca. 65"....John in CT
Old 04-06-2015, 05:32 PM
MBruns for President
JeremyD's Avatar
Seems right - I had plenty left over with two Each 89895K27 Type 304 SS Smooth-Bore Seamless Tubing 3/8" OD, .305" ID, .035" Wall, 6'Length
Old 04-06-2015, 06:21 PM
