Question headstuds/timeserts ??'s
Is it possible to tell, without a lot of teardown, which studs are installed and whether inserts have been installed in the crankcase walls?
I'm still in the process of figuring out what's been done to my 77 over its lifetime, since I have no records at all.
TIA
Dave
'77 911S
inari77s@911fanatic.com
Rochester, NY
Old 09-27-2001, 08:26 AM
davis911s's Avatar
Post
I think I read somewhere that once you have the covers off (next time you check valve clearances) use a magnet, if the magnet sticks the the head studs the are NOT DILAVAR, they are the metal ones and are the ones that cause problems. Someone else will chime in to verify if this is right.
Shawn
Old 09-27-2001, 08:46 AM
critter's Avatar
Post
Someone else could probably answer this better but I was told that rebuilders are now going back to original studs (not divlar)with timeserts.Aparently there was alot of problems with divlar studs if the coating got scratched.Anyway Warren or John W will probably chip in with some clearer amswers.
Grant 75 911s targa
Old 09-27-2001, 09:43 AM
