Micah (guest)
Guest
Posts: n/a
I have a 912E and the needle sits at the bottom of the gauge like it's dead. When I shift into reverse, the needle springs to the top of the gauge. Any suggestions on where to start troubleshooting?
This post was auto-generated based upon a question asked on our tech article page here:
Old 02-26-2015, 07:37 AM
Do the reverse lights work?
- Casey
- Casey
Hi Casey,
The reverse lights are not working.
Old 03-09-2015, 12:16 PM
Porsche Crest
Bueller?... Bueller?... Bueller?
Old 04-17-2015, 03:33 PM
Did the gauge ever work correctly? Check the part number on the sending unit, make sure you have the correct one for a 912E
Lucky owner of a couple of 911’s and a 924
Old 04-17-2015, 05:51 PM
Hi Patrick,
the gauge has worked correctly. Unfortunatly, I think this all started after I had the trans rebuilt. Sounds like if a pin is left out during reassembly, the reverse lights would no longer come on.
If I knew the root of Casey's question I could keep digging, but I haven't found a connection between the gauge and reverse lights that would spark his question. It makes sense a connection is being made when I shift to reverse, pinning the needle to the top of the gauge, but I'm not sure where it's coming from.
Old 04-21-2015, 09:56 AM
