lespaul's Avatar
Another "rattle" post - drive train related
Stock 78 SC with 915.
This one sounds like someone put about 30 bbs in a coffee can and set it on the metal floor of the car. Someone not familiar with the car may not likely notice it. Almost a buzzing rattle.
It is not engine related, because it does not exist at any RPM when the clutch is disengaged or the car is in neutral. Thus, I conclude it must be drive train related.
It only exists when in gear and decelerating -- even when I just lightly let up on the gas or am barely maintaining speed. Most pronounced in 2nd at between 3000 and 3500 rpm. Can detect it in 3rd and 1st. Never tried in 5th. As the RPM's decrease the sound decreases. Drive train must be engaged and decelerating to hear the noise. Disappears on even the most gentle acceleration and engagement of drive train.
I would try to record it, but I doubt you could hear it with the other engine noise.
Ideas?
Brad
Inventor of SNAPGAP - The Valve Adjustment Solution
Patented in U.S. and Europe. Go to SNAPGAP.US or PM me.
https://www.pelicanparts.com/More_Info/SNPVAK11146.htm?pn=SNP-VAK11146
Old 04-14-2015, 06:34 AM
Check the Heat Shield on your Catalytic COnverter.
Christopher Mahalick
1984 911 Targa, 1974 Lotus Europa TCS
2001 BMW 530i(5spd!), Ducati 900 SS/SP
2006 Kawasaki Ninja 250, 2015 Yamaha R3
1965 Suzuki k15 Hillbilly, 1975 Suzuki GT750
Old 04-14-2015, 06:44 AM
lespaul's Avatar
Thanks. Gutted Cat and no heat shield. Definitely drive train related.
Brad
Old 04-14-2015, 06:46 AM
universeman's Avatar
I'm assuming it's different from the high-gear/low-RPM/trying-to-accelerate sound which sounds (in my SC) more like BBs in a plastic cup?
Jason - Austin, TX
82 911 SC targa (gone, but not forgotten)
92 968 coupe
Old 04-14-2015, 09:33 AM
lespaul's Avatar
Yes. I know that sound and it is not that.
Brad
Old 04-14-2015, 09:35 AM
sugarwood's Avatar
Is that what a failing wheel bearing sounds like?
1986 Bosch Icon Wipers coupe.
Old 04-14-2015, 02:41 PM
French Import
zippy_gg's Avatar
Check the CV joints bolts and re-torque.
Even if this was NOT the problem it is still a good thing to do!
Gilles & Kathy
Happiness is not having a Porsche in the garage... Happiness is having a Porsche on the road!
86 Porsche 911 Cabriolet, 2011 BMW 1200RT, 03 Saab 93 Cabriolet, 06 MB E350 Estate
Old 04-14-2015, 04:46 PM
mussberger's Avatar
I had a noise that sounded like that. Would come and go. I could get always get it to stop for a while by coming to a stop and putting it in reverse. After tear down for a refresh we found the reverse idler shaft bearings were perished. Last one in didn't put them in correctly.
1981 911SC Black metallic, no sunroof. Sold(damnit)2005 987Guards Red, Stuttgart build. Sold1978 911SC Bahama Blue, M491 look E class PCA race car.Sold with help from Pelican. Thanks! 2005 997 Black. Sold1988 930 Grand Prix White. Keeper. 2008 957 Basalt Black, Pneumatic suspension and PDCC.
Old 04-14-2015, 05:19 PM
SWS911's Avatar
Sounds like it could be a throw out or a mainshaft bearing issue.
Old 04-14-2015, 05:22 PM
Tired Member
DaddyGlenn's Avatar
lets see...Check my thinking on this..
No noise unless there is zero or deceleration load on the transmission, right?
That means no noise when rolling in neutral with clutch engaged or in gear with clutch disengaged, right?
So only when torque is applied opposite of engine rotation.
If that is true, then we are limited to places that torque would be felt most directly:
  • CV joints
  • Wheel bearings
  • Transmission/engine mounts
  • Any number of things inside the transmission
The first three can be checked easily. If its not one of them, drain the transmission fluid and see if anything falls out that shouldn't.
Glenn
Daily Driver - '78 911SC RoW
Endurance Racer - '85.1 944
Street/Track Project - '86 951
Race Project - 944 Spec
Old 04-14-2015, 05:42 PM
lespaul's Avatar
Thanks Glenn. Your protocol makes sense. I did recently replace the tranny and engine mounts so they may have loosened up. I will also check the other easy options.
Brad
Old 04-15-2015, 06:56 AM
