-   -   1983 911sc CIS injector lines? (http://forums.pelicanparts.com/porsche-911-technical-forum/860018-1983-911sc-cis-injector-lines.html)
Dave Kost 04-10-2015 09:31 AM
I need to flow test the injector on my new to me 83 911. It has the metal injector lines that are a pain to work around.
Can I swap out the flexible plastic lines to test the flow into baby bottles? I have a set from a 74 CIS system.
No problems do the swap?http://forums.pelicanparts.com/uploa...1428683391.jpg
Josh D 04-10-2015 09:37 AM
I see no reason why you can't. Banjo fittings should be the same.
boyt911sc 04-10-2015 12:21 PM
Fuel lines swap.........
Dave,
You need six (6) 8-mm x 1.0 banjo bolts & washers with your old plastic injector fuel lines to connect to the FD. Disconnect the metal fuel lines on top of the FD and remove the 6 adaptors. Take care of these adaptors because they are hard to find when you need one.
Tony
