-   -   MSD Rev Limit Setting (http://forums.pelicanparts.com/porsche-911-technical-forum/860183-msd-rev-limit-setting.html)
LUFTKUL 04-11-2015 02:17 PM
Installing a MSD Street Fire CD Ignition Box with MSD High Vibration Coil in a '77 911S with stock 2.7 SSIs and M&K 2 in 1 out.
What should I set the Rev Limit at? It comes with a 100 increment adjustment set at 6600rpm stock.
What should this be set at? Thanks for the help!
Ayles 04-11-2015 02:40 PM
I have been wondering the same thing. I have a bunch if rev limiting chips and not sure which one to use.
Tippy 04-11-2015 02:42 PM
Isn't redline annotated on the tach?
Steve@Rennsport 04-11-2015 03:53 PM
Set it at 6600 RPM since your engine has cast pistons.
LUFTKUL 04-11-2015 04:27 PM
Thanks Steve! My tach is more of a orange-ish redline block showing a range between 6400 and 6600.
merlinfe 04-11-2015 05:27 PM
I have the same set up in my '83SC with magnecore 8mm wires and a resistorless rotor. I set mine at 6500 and haven't had an issue with it over reving. I figure a couple hundred below redline wont hurt it.
Its a great set up for the price and beats the hell out of the alternatives.
-Steve
