-   -   Should I replace rusty exhaust studs on my "new" B&B exhaust? (http://forums.pelicanparts.com/porsche-911-technical-forum/860206-should-i-replace-rusty-exhaust-studs-my-new-b-b-exhaust.html)
sugarwood 04-11-2015 05:40 PM
First, I am hoping to identify what exactly my aftermarket exhaust is all about.
The 2nd post will contain pics of the rusty bolts in question.
The PO replaced the stock exhaust about 10 years ago.
The stainless parts of the exhaust still look brand new.
The receipt says B&B. Is that the same thing as Billy Boat exhaust?
SSI exhaust is a totally different brand, correct?
Here are some pics of the system.
The heat exchangers and muffer/tailpipe are obviously stainless replacements.
But, are those stock exhaust manifolds? They are not stainless steel.
Do you think they installed the new heater boxes around the OEM exhaust manifolds?
http://i59.tinypic.com/2ennpn7.jpg http://i60.tinypic.com/15rlj51.jpg http://i61.tinypic.com/xd8dq0.jpg
Here is the exhaust tip and muffler.
I am not a big fan of the massive chrome exhaust tip.
The combo is $999 at Auto-Motion (P900142) so I am not replacing the muffler.
Is is possible to replace just the tip with something more subdued and stock looking?
Got any suggestions?
http://i60.tinypic.com/3305l6b.jpg
http://i57.tinypic.com/xbmxq9.jpg
sugarwood 04-11-2015 05:41 PM
Ok, here are the rusty exhaust studs coming out of the cylinder.
They bother me since they look like a dead tooth amid a brand new looking exhaust.
Is this another clue that the exhaust manifolds/headers are original to the car?
Plus, if I ever ran into a situation where I needed to remove the exhaust, I'd be dead in the water.
Like if I had to remove the bumper and muffler to open a stuck engine lid, that would be a problem.
Is it a big job to have a mechanic replace these?
It seems very hard to get to all 3 cylinders.
This is the most visible one.
http://i58.tinypic.com/r255l5.jpg
Here is a rusty bolt that attaches the headers to the muffler.
I assume this was new, so how can it get so rusty?
Were these just some cheap ass bolts that were used?
Would you replace these bolts?
What type of bolts would you replace them with?
http://i61.tinypic.com/4tkf89.jpg
http://i57.tinypic.com/rbxspe.jpg
sugarwood 04-11-2015 05:47 PM
In summary, here are my 3 questions:
1) Can you verify what sort of aftermarket exhaust system I am running?
2) Can I replace just the exhaust tip? If so, what can I use? I'm not sure what will fit onto the B&B muffler.
3) Are those the original exhaust manifolds? Or are they headers? How can I tell the difference?
4) Should I pay a mechanic to replace the 6 rusty exhaust studs (on each side) from the cylinders?
5) Should I try to replace the 2 rusted bolts (on each side) that attach the headers to the muffler?
This job seems within reach. I might even be able to remove the bolts without a Dremel.
Trackrash 04-11-2015 06:04 PM
What year car?
1. I believe that exhaust tip can be replaced. Others with more experience may chime in.
2. Those are not Porsche headers. They are headers with a heater box.
3. I would try to save your exhaust studs, assuming they are still ok. Wire brush the threads and see if they clean up and a nut will work on them. I have found that anti-seize brushed on the exposed threads does a good job of protecting them.
They are a biatch to replace. Involving drilling, tapping, and lots of profanity. There is a good chance that someone could botch the job and make things worse. If the motor was apart, it might be a no brainer. to replace them.
4. If it were me, I would replace the bolts to the muffler. I have had good luck with stainless in those locations.
Oh Haha 04-11-2015 07:05 PM
If it were me I would leave the rusty bolts/nuts at the heads alone. I know they don't look pretty but if they seal leave them until you need to remove them.
The tip could be replaced by a competent muffler shop with whatever you want. The pipe and tip will slide out of the muffler.
The bolts that attach the headers to the muffler could be done in the driveway in a few hours. Use SS hardware with a dab of anti-seize.
ClickClickBoom 04-11-2015 11:29 PM
Galvanic corrosion, lots written here and everywhere else too.
Bill Douglas 04-12-2015 12:39 AM
I would leave them well alone.
This is the sort of mini project that quickly becomes a great big expensive one.
michael lang 04-12-2015 12:50 AM
I agree with everyone here, you are better off leaving the manifold studs alone. If you start messing with them, as corroded as that one is, a month's worth of soaking with PB Blaster isn't going to help that thing. One or more will end up breaking and the next thing you know you will be posting about hosting an engine drop party and the pizza and beer will be on you. Just leave it be, you can't see it while your driving, and it's doing it's job. You're wise to not open a can of whoop ass because that's exactly what that stud/nut will do.
sugarwood 04-12-2015 05:44 AM
Thanks for the guidance. I just seems weird that if my car had aftermarket exhaust headers installed only 2000 miles ago, you would think the exhaust studs were cleaned during that job. Just seems weird they are SO rusty after only 2000 miles, and being garaged that entire time.
In any case, it sounds like the exhaust studs are a no go zone, and a job for a professional. I was never planning on doing that myself, but was asking if I should pay a pro to replace them. You guys are saying it's not worth paying someone to do it, since it is a major job, since the studs are likely to break? Is replacing exhaust studs a job that pretty much requires an engine drop?
Do you guys think it's low risk to attempt replacing the headers->muffler bolts? The are easily accessible and can be ground down, if need be. Plus, they are not studs but just bolts. Again, those are definitely new from the muffler install, so it's bizarre to think how they got so rusty, so quick. Do you think they actually reused the original bolts??
Any other details on identifying my exhaust system? He installed a Weltmeister chip after the exhaust change, but I wonder if it's optimally matched to the new system. If I got a Wong chip, I would get the 93 octane with headers Wong chip, right? I am not sure if I have headers or an exhaust manifold.
john walker's workshop 04-12-2015 06:45 AM
I deal with way worse than that all the time. If you really need to remove the exchangers, be sure to use oxygen/acetylene to heat the nut red before attempting remove it. Do one at a time and you should not break any studs. In a rare instance, some actually come loose with just a squirt of penetrant. you can try it, but don't lean on the wrench too much. As far as replacing the studs goes, best to let sleeping dogs lie.
Cook&Dunning 04-12-2015 07:01 AM
I would say you have B&B BillyBoat headers and muffler. I have attached a pic of my car - This is a track car I am bringing back to street. I agree with you that the tips are big and ugly. I think in a race application my set up was good - my headers are 1.75" diameter, but for street I think the combo of headers and muffler sacrifice low end torque. ON the B&B website, 1.75 is the size indicated for my 3.2. I have read a lot on the forum and my take is that the quality of the headers are pretty good, the muffler not so much. Meaning you could probably sell the headers, but the muffler is scrap. Which is probably a good thing because the muffler also weighs a ton.
I cut the flange and elbows off the B&B muffler took it to a muffler shop and they fabbed up this magnaflow for me Jack Olsen style. It cost me $200 all in and probably weighs half. This is a temporary measure for me as I am going back to stock headers and Euro premuffler.
Just an idea if you decide to tackle the exhaust tip redo.
http://forums.pelicanparts.com/uploa...1428850286.jpg
sugarwood 04-12-2015 11:56 AM
Cook, thanks for the info. I'm not looking to replace any part of my exhaust, as this is a big dollar item, and a low functional yield. But, I may look into replacing my tailpipe with a simple steel pipe, since that is viable and relatively low cost.
Last thoughts on replacing the headers->muffler bolts? The are easily accessible bolts (not studs) and can even be cut off, if need be.
Just don't use stainless on stainless? Just get copper bolts or something? Would you replace the crusty gaskets also? Will there be a lot of play if bolt is cut off?
Cook&Dunning 04-13-2015 06:37 AM
I went with factory nuts, bolts and gaskets. I torqued them to 17lbs (that was the number for my Cayman exhaust, so I figure it is probably good) 2 of the three on each side are pretty easy to get at, 3rd one a bit harder, but not too bad.
gtc 04-13-2015 08:02 AM
Stainless on stainless is fine.
My B&B's came with a set of hard copper gaskets that were good for repeated use... you might contact them for a set of these. A lot of people have reported bad customer service from B&B, but my several dealings with them were just fine.
They could also probably sell you a plain outlet pipe without the rolled tip.
Trackrash 04-13-2015 08:40 AM
Has no one heard of anti-sieze? I would think any "pro" would use it.
I used it on my exhaust studs in 1985 after I rebuilt my motor. Two years ago I had to remove my heat exchangers. Every nut came off with only a ratchet. No stripped threads, no broken studs, no torch.
shadowjack1 04-13-2015 09:26 AM
I have used anti-seize on my last top end. Every time I do a valve adjustment I loosen and retighten all the bolting on the H/E. Been doing this for years. It just takes a few mins. Works for me.
Dpmulvan 04-13-2015 02:19 PM
I have just spent the last two days trying to get my heat exchangers off and I still have one side to do. You couldn't get those off with the motor in the car if you wanted to.
Cook&Dunning 04-13-2015 02:58 PM
Yes, anti-seize on all of the exhaust to header bolts, and when I pull the B&B headers off it will be going on the studs
sugarwood 04-13-2015 04:25 PM
I will try to replace the header->muffler bolts, and I think that should be safe.
They are less rusty than the studs, and might come off with just a socket.
It just bugs me that the exhaust studs are only going to get more rusty from here.
I have no plans to ever replace the exhaust, but a top end valve job needs to remove the exhaust, right?
If a pro mechanic ever needs to remove the exhaust, it going to be a *****, right?
Maybe I will try to wire brush the studs, but some of them are blocked by the heat exchangers.
86 ssinit 04-13-2015 04:49 PM
It's a billy boat headers and muffler set up. I installed the same system on my sons 83. we did it about 2 years ago and my son is replacing the muffler bolts with stainless bolts soon because of rust. Soak them with pb blaster for 2 days and they should come loose. Just had a valve adjustment done and my mechanic didn't say anything about removing the exhaust. As for the studs billy boat has a special tool for removing the nuts. Without it some of them are in really hard places to reach. I think some of those nuts took me over 2 hours to tighten without the tool. I don't think I could remove them now without the tool. Good luck.
sugarwood 04-13-2015 06:11 PM
Billy Boat Porsche 911 Carrera Header Muffler Kit w Heat Exchangers B B Exhaust | eBay
Yea, this Ebay ad confirms it is Billy Boat with the stainless air box and muffler, but cast iron headers?
What are the upright slanted pipes protruding from the back side of the heater boxes? I don't think I have those.
http://i.ebayimg.com/00/s/MTIwMFgxNj...VCuWI/$_57.JPG
sugarwood 04-13-2015 06:28 PM
Any idea where to buy the billy boat exhaust bolt removal tool ?
Yea, you can barely even see all 6 of the exhaust stud bolts.
so that is what made me wonder if this is going to become a problem down the road.
I guess in an extreme worse case scenario,
a mechanic can just Sawzall the whole exhaust off,
thereby exposing all the exhaust studs (for possible drilling out)
Then just purchasing a new header/air box combo.
gtc 04-14-2015 08:43 AM
The B&B headers are stainless, not cast iron. Yes, stainless can rust.
The slanted pipes coming out of the heater boxes deliver heat to your heater valves, which direct the hot air either to your cabin or out underneath the car.
For removal tools, a flex-head gear wrench works well. I'm not aware of any special B&B tool. There is an SSI tool that might help, but I never cared much for it.
Why bother wire brushing the rust off the exhaust studs? They're just going to get rusty again.
You are really making way too big a deal out of this. Everyone's exhaust studs get rusty.
Ayles 04-14-2015 09:08 AM
Here is the tool that comes with the B&B exhaust:
http://forums.pelicanparts.com/uploa...1429031273.jpg
sugarwood 04-14-2015 02:38 PM
That's one heck of a tool.
Is that used only for one particular cylinder?
Gtc, yea, I was mostly curious.
My engine is so clean and dry, it just seems to weird to have those rusty bolts stick out like a sore thumb.
Studs are probably is a moot point for a long time.
And if the engine is out, the studs will probably be the least of my worries. (and can be drilled out at that time, if needed)
I might replace my muffler bolts for the experience.
sugarwood 05-05-2015 01:18 PM
http://i61.tinypic.com/4tkf89.jpg http://i57.tinypic.com/rbxspe.jpg
On a whim, I tried to remove these muffler bolts today.
Wire brushed the threads, then PB Blaster.
I didn't jack up the car, so I had poor leverage, so they didn't budge with the 3/8" ratchet.
When I have more time, I will jack the car and see if I have more room to work.
I can see this being harder than it looks.
It's actually a pretty tight fit up in there for the other not pictured bolts.
I'll need to use a 2nd wrench to hold the bolt head still.
If I can't get them to move, getting a Dremel onto all 6 bolts may be tricky.
sugarwood 05-14-2017 04:05 AM
This muffler bolts thread popped into my head today. (Not the exhaust studs)
Back then, I see that I futilely tried to use a 3/8" ratchet to remove the muffler bolts.
Today, I'd use a 1/2" breaker bar.
In the 2 years since I made this post, I have purchased impact swivel sockets and both a 3/8" and 1/2" 18V electric impact gun.
So, I'd like to revisit replacing the rusted header -> muffler bolts, if there is access.
How can I figure out what size/material bolt I should replace them with?
Also, is there a standard size for the gasket?
RarlyL8 05-14-2017 05:31 AM
If you plan on keeping this car for another 10 years remove those cheap a$$ studs and nuts NOW.
It will only get worse. If you don't feel comfortable doing it take it to a P-mechanic. You don't want those carbon steel studs rusting up in the heads. Replace with stainless studs and copper nuts and you'll never see this again. For the muffler you can use stainless nuts, bolts and washers, that is what we use.
Quicksilver 05-14-2017 05:18 PM
I've got B&Bs on my car for over a decade...
For the exhaust manifold nuts I would get them off (listen to John Walker) and replace them with copper plated locking exhaust nuts with copper antiseize. (The aluminum antiseize is junk.) If the studs are REALLY toast you can clean the threads with a thread cleaning tap which is different then a regular tap. (It won't remove metal.) Note that the copper plated nuts are a smaller hex size (12mm) so they are easier to get a socket on. I purchased an offset 12mm boxend wrench and cut it in half for clearance which works great for the nuts that I can't get with a socket. Just use the factory exhaust gaskets.
For the header to muffler flange you can use the factory 3.2 muffler gasket or any 2-1/2" header collector gasket but I've found I got the most re-usability out of using a copper gasket (Mr Gasket I think). I've found the perforated metal and fiber gaskets work very well too. Use stainless allen head bolts with copper antiseize and the same copper plated exhaust nuts as the manifold flange. Stainless bolts with stainless nuts isn't a good idea as it tends to gall. Also stainless with steel promotes galvanic corrosion.
One additional thing is I'd make a maintenance item of loosening, re-antiseizing, and retightening the nuts every 2-3 years. You will never have a chance of an exhaust stud issue again.
Flat6pac 05-15-2017 04:41 AM
I've done the install a couple times on B and B exhaust. I couldn't possibly imagine doing the install in the car.
On an engine stand, working down still having problems with getting the nuts on the studs.
It's a night mare to get tight.
Wearing threads on the exhaust studs? Try prevailing torque nuts on the studs, and antiseize.
Bruce
