-   -   Installed clutch cable... need some help troubleshooting (http://forums.pelicanparts.com/porsche-911-technical-forum/860331-installed-clutch-cable-need-some-help-troubleshooting.html)
mreid 04-25-2015 06:40 AM
http://forums.pelicanparts.com/uploa...1429921730.jpg
But this is his picture and you can clearly see that the snap ring has not been removed. Therefore, there is no way the shaft could have moved that far back without the fork moving/bending/breaking. Also, the fact that the clutch lever has no spring pressure from the pressure plate spring confirms it.
Of course, I could be wrong...
uwanna 04-25-2015 06:48 AM
+1 ^^^^
I agree Mreid, I think you are dead on correct! It's engine/tranny pullin time. Best of luck!
