Another Fred Cook fan (Fuse Panel)
Hi guys,
It's Winter in Chicagoland, and perfect for doing wiring projects. I ordered Fred Cook's basic ATO blade type fuse panel. I already have headlight relays installed. He sent it to me in a very few days. It is beautifully made, and very well documented. It took me 7 1/2 hours to install, but hey it's Winter so who cares? I have pictures, but they are no different than anyone else's. It is tedious work, and it is easy to miss a wire on the lower fuse connectors when you are disassembling the old panel. But go carefully and label each terminal wire/wire group. I did all the tops, crimped, heat shrunk and labeled them. Then I did the bottom the same way. Then you pull the old fuse blocks, and verify where the jumpers are so they match Fred's. Then I installed the bottom, screwed the new panel in place, then inserted all the top wires. Removing the relays aids in exposure for the top.
When I was done I reconnected the battery ground strap, and everything worked perfectly. I spent about 15 minutes removing my labels to make things neat. Then I covered it all up by replacing the stock fuse box cover, and nobody will even know I did anything.
I am going to replace the 3-fuse block in the engine compartment with an ATO type in the next week or so.
Anyway, Fred's product is fantastic, and he seems like a very competent and helpful guy. I am very grateful to him.
Thanks,
Dave
Dave McKenzie
1984 Carrera 3.2
1984 928S Automatic
2001 996TT
Old 02-27-2015, 07:30 PM
evan9eleven's Avatar
^^^ What he said! Just did mine and it turned out great.
1981 911SC restomod "Minerva"
2004 Boxster S
2021 Cayman GTS 4.0 manual "Olive"
2014 Cayenne GTS V8 (wife's lover)
The slope is not slippery; in fact it is entirely frictionless.
Old 02-28-2015, 01:39 AM
fred cook's Avatar
Thanks!
Thanks for the kind words, guys. Just doing my job! I know how tough it is to buy parts for a hobby car these days and how much Porsche owners want their cars to be "just right"! If anyone has a suggestion for improvement, please let me know. Happy driving!
FEC3
1980 911SC coupe "Zeus" 3.3SS
god of thunder and lightning
Old 02-28-2015, 03:24 AM
Hi Dave,
What is headlight relay? Is this some kind of modification?
Is it for 911sc?
Old 04-13-2015, 10:44 PM
ghamilton's Avatar
Hotaru:
Our host sells the JWest plug and play upgrade. About 1 hrs work and a must do if you want to spare your high beam stalk from meltdown.
Ask me how I know!
G. Hamilton
'82 SC Guards Red-2nd time owned-Now sold
"Bumerang"
'70 TR6
N of Boston
Old 04-14-2015, 04:27 AM
