-   -   Annoying Rattle (http://forums.pelicanparts.com/porsche-911-technical-forum/860463-annoying-rattle.html)
Targa Me 04-13-2015 01:39 PM
Annoying Rattle
Hello Everyone,
Subject: 1984 with a stock 3.2, 320k miles on the clock.
The car has developed an annoying rattle. (Comes from the rear of the car)
The rattle is heard when the car is warmed up. Does not rattle first thing in the morning.
1. Doesn't matter if the clutch is engaged or disengaged.
2. Rattle is not affected by engine rpm.
3. Doesn't matter if the transmission is in gear or not.
4. I can't hear the rattle while driving, meanly because of road noice.
5. Seems to be worse after driving for 15 to 20 minutes.
6. After the car sits for 20 mins, after the 20 min drive, the rattle is barely noticable.
7. Over time, rattle is getting worse.
8. I lifted the car, knocked on parts and pieces with a rubber mallet but everything seems to be ok.
9. Gearbox shifts nicely.
Any ideas ? :confused:
Thanks.
pete3799 04-13-2015 01:56 PM
Muffler maybe? Internal baffle loose perhaps.
Targa Me 04-13-2015 02:01 PM
I tried tapping on the muffler and didn't hear anything, but maybe an internal baffle ! I never thought of that.
thanks.
DRACO A5OG 04-13-2015 02:03 PM
Brother Larry,
Can you post a video?
Jim
Targa Me 04-13-2015 04:25 PM
I'll see what I can do.
sugarwood 04-13-2015 05:19 PM
Did you poke around the rear while the engine was running?
DRACO A5OG 04-13-2015 05:32 PM
I believe he stated it only happens at speed.
Targa Me 04-13-2015 06:48 PM
I need to lift the car when its hot and run the car for further Dx.
tirwin 04-13-2015 06:51 PM
Loose chain tensioner?
DRACO A5OG 04-13-2015 07:13 PM
Does it sound like a rattling tin trash can? Which oil are you using?
sugarwood 04-13-2015 07:30 PM
He said he can't hear the rattle while driving.
DRACO A5OG 04-13-2015 07:34 PM
^^^, oops my bad, damn old eyes :(
Well that is good news.
jwakil 04-13-2015 09:45 PM
Sounds like catalytic converter. It might have a big chunk broken apart internally so you have a piece or pieces rolling around in there. Eventually the pipe will get clogged and bog the engine down. I had this experience before. Also makes sense that the sound would be affected by the temp.
Targa Me 04-14-2015 05:05 AM
I would think that a loose tensioner would make the noise regardless of the engine cold or hot.
My rattle is only when the engine is warmed up.
Targa Me 04-14-2015 05:07 AM
I'm using AMSOIL 20w-50.
The rattle is not tinny, more of a dull clunk noise.
Targa Me 04-14-2015 05:08 AM
This weekend I will remove the muffler and CAT to see if I can hear something loose in them.
tirwin 04-14-2015 05:10 AM
You're probably right. I said that because no one else had and you wouldn't want to drive it if it was a tensioner.
Can you record a video and post it? That might help narrow it down.
