Hi
Targa Me's Avatar
Annoying Rattle
Hello Everyone,
Subject: 1984 with a stock 3.2, 320k miles on the clock.
The car has developed an annoying rattle. (Comes from the rear of the car)
The rattle is heard when the car is warmed up. Does not rattle first thing in the morning.
1. Doesn't matter if the clutch is engaged or disengaged.
2. Rattle is not affected by engine rpm.
3. Doesn't matter if the transmission is in gear or not.
4. I can't hear the rattle while driving, meanly because of road noice.
5. Seems to be worse after driving for 15 to 20 minutes.
6. After the car sits for 20 mins, after the 20 min drive, the rattle is barely noticable.
7. Over time, rattle is getting worse.
8. I lifted the car, knocked on parts and pieces with a rubber mallet but everything seems to be ok.
9. Gearbox shifts nicely.
Any ideas ?
Thanks.
"A good sense of humor is the best thing to have in your toolbox when working on these cars."
Quote by Charles Freeborn, Pelican.
Old 04-13-2015, 12:39 PM
pete3799's Avatar
Muffler maybe? Internal baffle loose perhaps.
Pete
79 911SC RoW
Old 04-13-2015, 12:56 PM
Hi
Targa Me's Avatar
I tried tapping on the muffler and didn't hear anything, but maybe an internal baffle ! I never thought of that.
thanks.
Old 04-13-2015, 01:01 PM
Member 911 Anonymous
DRACO A5OG's Avatar
Brother Larry,
Can you post a video?
Jim
'85 Carrera Targa
PCA/POC
Old 04-13-2015, 01:03 PM
Hi
Targa Me's Avatar
I'll see what I can do.
Old 04-13-2015, 03:25 PM
sugarwood's Avatar
Did you poke around the rear while the engine was running?
1986 Bosch Icon Wipers coupe.
Old 04-13-2015, 04:19 PM
DRACO A5OG's Avatar
I believe he stated it only happens at speed.
'85 Carrera Targa
PCA/POC
Old 04-13-2015, 04:32 PM
Hi
Targa Me's Avatar
I need to lift the car when its hot and run the car for further Dx.
Old 04-13-2015, 05:48 PM
El Duderino
tirwin's Avatar
Loose chain tensioner?
There are those who call me... Tim
'83 911 SC 3.0 coupe (NA)
You can't buy happiness, but you can buy car parts which is kind of the same thing.
Old 04-13-2015, 05:51 PM
DRACO A5OG's Avatar
Does it sound like a rattling tin trash can? Which oil are you using?
'85 Carrera Targa
PCA/POC
Old 04-13-2015, 06:13 PM
sugarwood's Avatar
He said he can't hear the rattle while driving.
Old 04-13-2015, 06:30 PM
DRACO A5OG's Avatar
^^^, oops my bad, damn old eyes
Well that is good news.
'85 Carrera Targa
PCA/POC
Old 04-13-2015, 06:34 PM
jwakil's Avatar
Sounds like catalytic converter. It might have a big chunk broken apart internally so you have a piece or pieces rolling around in there. Eventually the pipe will get clogged and bog the engine down. I had this experience before. Also makes sense that the sound would be affected by the temp.
82 - Austin Mini 998
78 Mini 1275cc -totaled
83SC Euro w/77 3.0 Carerra Eng.--sold
Several other daily drivers not worth mentioning...
Old 04-13-2015, 08:45 PM
Hi
Targa Me's Avatar
I would think that a loose tensioner would make the noise regardless of the engine cold or hot.
My rattle is only when the engine is warmed up.
Old 04-14-2015, 04:05 AM
Hi
Targa Me's Avatar
I'm using AMSOIL 20w-50.
The rattle is not tinny, more of a dull clunk noise.
Old 04-14-2015, 04:07 AM
Hi
Targa Me's Avatar
This weekend I will remove the muffler and CAT to see if I can hear something loose in them.
Old 04-14-2015, 04:08 AM
El Duderino
tirwin's Avatar
You're probably right. I said that because no one else had and you wouldn't want to drive it if it was a tensioner.
Can you record a video and post it? That might help narrow it down.
Old 04-14-2015, 04:10 AM
