-   -   Updated project (dont open if you dislike carbs or unpolished fans) (http://forums.pelicanparts.com/porsche-911-technical-forum/86067-updated-project-dont-open-if-you-dislike-carbs-unpolished-fans.html)
ErVikingo 11-01-2002 10:31 AM
Guys,
For those of you who enjoy the mechanical aspects, I took these yesterday. Motor is finally together and will go on the dyno as soon as we install the Electromotive.
Juan
http://forums.pelicanparts.com/uploads/m1.jpg
http://forums.pelicanparts.com/uploads/m2.jpg
http://forums.pelicanparts.com/uploads/m3.jpg
http://forums.pelicanparts.com/uploads/m6.jpg
http://forums.pelicanparts.com/uploads/diff1.jpg [img]
http://www.pelicanparts.com/support/smileys/fork_off.gif[/img]
Joe911 11-01-2002 12:05 PM
Juan - looks great. A 2.0 engine for the vintage racer? Also see the PMOs. Have you used them already? Much difference from Webers?
Best regards from Gainesville -
ErVikingo 11-01-2002 12:30 PM
Joe,
see my private message to you. Juan
Two Oh 11-01-2002 08:11 PM
Nice Juan,
Tell me about your manifolds. PMO? Taller than stock? Advantages if any?
Regards,
2.0
ErVikingo 11-02-2002 08:14 AM
Hello 2.0,
I'm using a full PMO setup, I replaced everything from my prior Weber 4o setup with the PMO don to linkages and all. There was nothing wrong with my Webers (actually they are probably the fines set out there) but I'm looking for high RPM operation and need high flow rates (thus the 46 PMO instead of the 40 eventhough it is a 1991cc motor).
According to PMO these manifolds complete the setup required for my application, I'm not sure they are higher though as I have not measured them. I'll do that later and get back to you with more info.
Juan
