-   -   Does this sound like a stuck relay? (http://forums.pelicanparts.com/porsche-911-technical-forum/86111-does-sound-like-stuck-relay.html)
DJB 11-01-2002 09:09 PM
HELP Does this sound like a stuck relay?
My washers and wipers go into intermittent mode each time I start my car. So I get a free screen wipe and spray each time - great in a convertible!!!
After discussing this problem on this board we though it may be the wiper switch. I have the switch apart now and yes its old and needs a clean, but I do not think it's the problem.
In my mind - if it was the switch then the wipers would continue to wipe in intermittent mode - is this thinking correct?
I am wondering if the intermittent relay is geting stuck when I turn the car off and therefore, when I start the car it causes one cycle and then returns to normal. - Is this logical - how would I test if it is the relay or the switch?
Any help would be much appreciated - the next step will be to remove the fuse until I sort it out, not a great step for a daily drive.
Can someone also confirm if the relay is under the fresh air blower in the luggage compartment on an 86 cab.
Thanks.
DJB 11-01-2002 10:02 PM
According to Bentley's wiring diagram, the 86 does not have a relay, but (a no doubt expensive) intermittent wiper control module. I can definently hear a thunk like a relay closing when the wiping cycle is finished.
Has anyone seen this module, or know about its workings - it does not seem to be listed on Pelican as a part.
DJB 11-02-2002 03:40 PM
Pleeeez - Bump
TurboBert 11-03-2002 09:16 AM
David,
I don't know if this is going to help much because I don't have a wiring diagram for an '85. But looking at the schematics for an '83 SC, I notice there is a "Pulse Transmitter" that is wired between the the washer pump and the wiper motor.
It looks as if this is faulty, it could bypass your wiper switch. Do you think this is worth checking?
