Does this wheel look like a 9"
I know I know why not just pull it off and check and I will I've just been very busy. Does this look like an original Fuchs 9". The tire on it is a 245/50/16. I really like the way it fills the wheel well. Give me your best guess and I'll post after I pull it off. The option sticker under the bonnet says the car came with light weight wheels but not if they were 7's and 8's or 8's and 9's. Thanks
Under the radar
Could be an 8 or 9 inch. Real Fuchs have the size stamped on the back side of the wheel.
Not 9's, lug nuts don't set deep enough.
They really look a lot wider then the 8" X 16 on the Targa.
They don't look like 9's to me. Maybe 8's.
Lou |
Paper Member
What size tire is on it?
Nevermind, I blew up the photo and can see its a 245/50. It's a 9" I'll bet. Sent from my iPhone using Tapatalk
Enemy of the State Brandolini’s Law: It takes hours more time, research, and writing to debunk misinformation than it takes to spread it. Last edited by DaveE; 04-19-2015 at 07:32 AM.. |
Go-Kart Mozart
This. The wheel pictured is 16x8. The lug holes give it away. Lug nuts are deeper set on the 16x9. Also 245 won't show that much sidewall bulge on a nine. FWIW I have 245s on 16x9s. My wheels have the deep set lug holes. -J
86 Carrera Every normal man must be tempted at times to spit on his hands, hoist the black flag, and begin to slit throats. H. L. Mencken |
Thanks for the guesses and info, I'll check it when I get a chance
non-whiner
You can find out in less than two minutes with a tape measure. I also say 8".
"Too much is just enough." |
Checked out
[QUOTE=spb350;8583710 Does this look like an original Fuchs 9".
[/QUOTE] As several posters above have pointed out, there's no need to guess. The picture 100% conclusively shows that it is not an original Fuchs 9. The lug holes easily prove it. |
weekend wOrrier
here's a so-so pic of the sunken lug bolts on a 9 inch wide.
![]() You have an 8 inch rear rim. |
The 7&9X16 Fuchs off my cab ![]() ![]() 7&9X16s on my 78 SC ![]() These are 7&8X16 951 Fuchs off an 86, one year only, notice the recessed lugs. ![]() A close up of the 9X16 on the back of my 914-6GT clone ![]() 8X16 911 Fuchs on my 88 ![]() ![]() As you may have figured out, I have a fetish for Fuchs and NO they are not for sale.
Byron ![]() 20+ year PCA member ![]() Many Cool Porsches, Projects& Parts, Vintage BMX bikes too |
Are you open to trades... Sorry couldnt resist. Awesome wheel collection.
78 911 st backdate 87 944 00 996 |
[QUOTE
As you may have figured out, I have a fetish for Fuchs and NO they are not for sale. [/QUOTE]. So they have this show on TV called hoarding and.......................
