Porsche tax! Need $2 part Not $75 assy. HELP
The door handle on my 86 coupe has lost the steel pin and spring. Fell out and disappeared during painting. Porsche does not service these parts and says I must buy the whole door handle assy. I didn't even ask the price. Parts Heaven wants $75 for used assy.
Does anyone have a broken, beat up door handle with an intact steel pin and spring they would sell for a lot less than $75 Boy this makes me sound really cheap. Oh well, I am really cheap. David |
David,
Is there some way that you can put a dial calipers on the other pin and send the dimensions to me. I can ask one of the machine shops that I work with and they can cut one for you no charge I'm sure. The spring? Most good hardware stores have a selection. You sale reps ignore the following. Or,if you send the spring dimensions to me I can ask a spring vendor for a sample. S/H won't be more than the cost of a stamp. Send me an e-mail thelancials@msn.com Mike P.S. I'm cheap too!!
Thanks, Mike When I was a kid, I didn't want a stupid pony, I wanted a PORSCHE. 1970 911T Coupe, 1979 911SC Targa Euro, 1971 Honda CT70 HK Trail 70 (the ultimate in two wheeled transportation) |
It's just not a Porsche tax. Ford, GM, VW, etc. now operate the same way. Many parts now only come in assemblies.
Jim
Thanks for your post.
Sometimes tunnel vision makes common sense fly out the left and right ears. There is a machine shop down the street from my shop. DUH!!! No doubt your advice will work there as well as in Minn so I will try them first. I will just carry the remaining pin in the front door. I appreciate your help. Home Depot probably has a spring that will work. That is where I bought the clevis pins for the door stays. And I promise never to complain about cheap, stupid people again. Particularly when I am being the cheap, stupid person. Thanks David |
Stressed Member
David-
I have a door handle from a '70 that has a broken stud. My guess is that it has the pin you need. Let me know if I can help.
'70 911E short stroke 2.5 MFI. Sold ![]() ![]() ![]() '56 Cliff May Prefab |
Ditto
On the assembly stuff. Toyota apparently is doing it also.
Wipers on the Avalon stopped in a pouring rain. Dealer says $400 for assembly, plus install. Drove to a friend (with head out the window and rain in the face) found out a clip had slipped off, replaced with a pair of pliers. Still working after 3 years. Not only cheap, but OLD and cheap
Impotence...Nature's way of saying "No hard feelings." McDaniel 1974 911 Targa 1995 Toyota Avalon 2004 Toyota Tundra Extended Cab |
David, do you see the piece you need here?
Robert Stoll 83 911 SC 83 944 |
The little steel pin in the middle. The spring, which I don't see in the picture, is shorter than the pin. Both pieces fit in a groove in the second largest black piece. (right angles and the thing you put your fingers on to open the door). This black piece is held in place by the stud you see pictured.
I was going to measure the size of the hole, and thought a simple way would be to slip in different size drill bits until I found the correct size. Then, like an apple hitting the top of my head, it came. If all else fails, a broken drill bit cut or ground to the correct length would serve. And as an added benefit the edges of the bit would keep the hole clean in perpetuity. With that kind of thinking, opportunity awaits me scripting infomercials. But, since I have the time and the assistance, I would rather have the correct parts. Thanks for the pics David |
David, email me your address and I will send you the pin. I will look again for the spring, but didn't see it in the bag "o" stuff yesterday.
Dave, I just found the spring too. Amazing what you can see if you put your glasses on.
See, she was right. It just takes a village. If I complain about the price of tires, will anyone send me a new set for $2.
Thank you MR. DR. SUPERHERO Stoll !!!!!!!! David |
