Scott (guest)
Guest
Posts: n/a
89 911 Targa: high beams automatically come on when headlights are on? High beams can be disengaged when stalk is pushed forward and back but continues to happen over and over again? Is this a switch issue? What part is required to remedy?
This post was auto-generated based upon a question asked on our tech article page here:
Old 04-20-2015, 04:12 PM
Does your high beam/turn signal switch feel nice and tight when you push it forward, and pull it back? Did this failure happen after some other work was done to the car?? Does the "flash to pass" function work on your car?
- Casey
NOLAsc's Avatar
Sounds like an in-column switch issue. Have you read through this thread?
turn signal switch quick fix pictures
"... changing without pain or agony not only in bulk and shape but in color too, approaching the color of wind ...."
-- William Faulkner
Old 04-20-2015, 05:32 PM
ROW '78 911 Targa
timmy2's Avatar
Time to bend the contacts.
Then look into headlight relay kit.
Old 04-20-2015, 06:13 PM
autobonrun's Avatar
Yep, bad switch. Short term, fold a piece of thin cardboard and press it in the slot behind the stalk to hold it in place.
1979 Porsche 911SC Targa
1996 Porsche 993 C4S
2005 Porsche 996 Turbo S
2020 BMW X3M Competition
2003 BMW M5
Old 04-20-2015, 06:40 PM
