911 Headlight conversion
Dear Friends
My car ( the yellow one) have this kind of headlight on it, and i would like to change them to this style ( the picture of the headlight only)
Not being a Porsche guy i have no idea if it´s possible or what kind of parts will need to do this or where´s the best place to buy them?
Also I hear a lot of H1 H4, what are the difference? Do i have H1 or H4, is the one i want H1 or H4?
Can any one help me?
Old 08-08-2015, 01:38 PM
ricardo -- your car has "sugar scoops" and you're wanting "H4" headlights (the h1 headlights look similar to the H4, are no longer available, use 2 vs 1 bulb and are more $$$) --
Our host, pelicanparts.com has you need for this for sale -- you'd need to buy the lights you picture and, if you want to cover the chrome ring with a body-colored ring, would need to buy the trim rings and extra screw set. You'll also need to buy a pair of h4 bulbs and should get a new pair of headlight gaskets -- while doing the job, you should also get a headlight relay -- our host sells a headlight relay kit from jwest that is an easy install. good luck!
Old 08-08-2015, 02:20 PM
Hello,
Thanks for the help, I´m looking at pelicans, but still a little bit confusing, since there are a few choices that seems to work, but with a huge difference in price.
Thanks again
Ricardo
Old 08-09-2015, 08:13 AM
Originally Posted by 1ricardo View Post
Hello,
Thanks again
Ricardo
You need to get the complete H-4 headlight assemblies which will run ~$320+ each.
The much lower priced H-4s are for the bulb reflectors and bulbs only, which are designed to fit into the sugar scoop assemblies that you want to replace.
L.J.
Recovering Porsche-holic
Gave up trying to stay clean
Stabilized on a Pelican I.V. drip
Old 08-09-2015, 08:23 AM
Banned but not out, yet..
RSBob's Avatar
Search on Euro H4 headlight assembly. Unless you want to add relays, get the 55/60 watt bulbs. If you are not afraid of doing a little minor wiring, get the relay kit and higher wattage bulbs for superior light output.
Old 08-09-2015, 08:33 AM
you need two of these (the h4 assemblies you have pictured above): http://www.pelicanparts.com/cgi-bin/smart/more_info.cgi?pn=911-631-113-00-OEM&catalog_description=&Headlamp%2520Assembly%2520%252D%2520Bosch%2520H%25 2D%2534%2520%2520%2520%253Cfont%2520style%253D%252 2font%252Dweight%253Anormal%2522%253E%2520%2528Eur opean%2520with%2520Chrome%2520Rim%2529%2520%2528wi thout%2520Bulbs%252C%2520Left%2520or%2520Right%252 9%2520%2520
you'll also need two of the h4 bulbs on this page -- (I use the 55/100watt bulbs) 1986 Porsche 911 Carrera Targa - Lights and Lenses - Page 3
Finally, get and install the headlight relay kit: Pelican Parts - Product Information: JWST-911-HLPR
This is all you need to replace your sugarscoops with a pair of the h4 headlights pictured in your first post
Old 08-09-2015, 09:52 AM
Perfect! Thank you all
Old 08-09-2015, 04:20 PM
