G50/00 how much power can it handle
I have i g50/00 with a lsd and a billet sideplate for it. Does any one know how much this transmission can handle ? as it has the smaller pinion and ring.
1350ft/lbs
No further information needed :P thank you Tippy :)
Yes, plenty of power.
That's about the torque Eddie Bello broke 3rd gear on the dyno IIRC.
Yes, but I don't generally use Eddie in this sort of circumstance because his car runs 9 seconds at a time. ;)
We've put these in v8 powered kit cars for over a decade with good durability on cars used for both street and track. All Ultima GTRs use G50, as does the FF GTM Mulsanne. Seen plenty of 800-1000hp builds on those cars. |
Don't forget Texas Mile.
Eddie Bello has a newer g50 doesn't he ? Mine is a g50/00 and has a smaller ring and pinion. If that isnt a weak link it should be more than powerful enough. The reason i asked is that i've read somewhere in some old post that g50/0x couldnt handle very much , but people tell me different numbers.
I want to know how much it can handle with the stock smaller ring and pinion.
Dont know that answer but i fo know the R+p is a g50 weak point
Eddie had a 50/50 with large r/p but he broke the case. They've become so rare and expensive he went back to a g50/03. Same thing as a g50/00 but with 964 Tailcone versus 3.2 mount.
Don't worry about it. The internet is full of false rumours. Regards, Matt Monson Guard Transmission LLC. |
Great Matt thank you again .
| All times are GMT -8. The time now is 01:56 PM. |
