Czar of C.R.A.P.
dfink's Avatar
Cabriolet Linkage 1985
So the cab top finally arrived and appears to fit great. However I can't remember from my old car where the two arms attach. This is a manual system and there are two round arms with a pivot on the end. They are adjustable but I don't know where they attach.
Any help would be appreciated.
66 912 Coupe
84 Carrera Cab Hardtop HC3.4 Hyper Carrera
2005 Dodge Magnum 5.7 HEMI
Cabriolet Racing And Performance C.R.A.P. Gruppe #1
Put on some C.R.A.P. and drive....
Old 10-01-2017, 09:14 AM
proporsche's Avatar
Hi..i know this is ele.top diagram but it might help you
Ivan
Old 10-02-2017, 01:38 AM
Brew Master
cabmandone's Avatar
Are you talking about the arms that go under the cover just behind the front seats? If so, I'll go out and take a picture later this morning.
Old 10-02-2017, 02:19 AM
proporsche's Avatar
ok this should be better
Ivan
Old 10-02-2017, 03:05 AM
Brew Master
cabmandone's Avatar
Starting at the bottom where the adjustment arm mounts working to the top
Old 10-02-2017, 04:50 AM
Czar of C.R.A.P.
dfink's Avatar
That is the arm but is the part it bolts welded on or does it bolt on. This was originally a cab but the top was removed for a fiberglass hardtop and so I don't know what else might have been removed. It looks like the piece is maybe welded to the body.
Old 10-02-2017, 06:25 AM
Brew Master
cabmandone's Avatar
Good thing I didn't put the cover back on! The white piece the bolt attaches to on the lower part of the arm is welded to the pillar.
Old 10-02-2017, 08:14 AM
Czar of C.R.A.P.
dfink's Avatar
I was afraid it was welded. I think it was cut off to make room for the cage. There are two bolt holes above that. I may try a piece od angle and see it can be made to work that way. I cut the cage out as the top wouldn't fit wit it in.
Old 10-02-2017, 10:17 AM
proporsche's Avatar
Hi dfink..i had an idea there must be more to this then you forgot where it goes..you did not mention cage;-)
cross my finger for you good luck...
Ivan
Old 10-02-2017, 10:23 AM
Czar of C.R.A.P.
dfink's Avatar
Well I forgot as compared to another cab I used to have. If the bracket would have still been there I probably would have figured it out. I am not sure if I cut the bracket or it was already gone. The car had fiberglass hard top when I bought it. But I did the cage
Old 10-02-2017, 10:42 AM
Brew Master
cabmandone's Avatar
I'll double check to make sure it's welded as I took a pretty fast look at it and the carpeting is cut around it. I'll let you know if I see anything any different. I can't see a reason they'd cut it out and I'd think there would be evidence of it being ground or cut with a saw unless they did a REALLY nice touch up job.
Old 10-02-2017, 12:57 PM
Czar of C.R.A.P.
dfink's Avatar
Well I think the too is in and working. I just made a bracket out of an old bed frame. Everything seems to work as it should. I will need to adjust the windows a bit to tighten up the seal but the window zips and top latches good and tight. Thanks for the pictures they helped alot. Now I guess I will need to get rid of the hard top.
Old 10-02-2017, 03:21 PM
