Can you disconnect your fan belt and run - just for a moment - to eliminate the fan and alternator?
Franny |
Remove the fan belt and check. Do not run for a long time, just enough for a listen.
I have my buddy's Good Dizzy, will be checking against my rebuild. His is tight and 0.10MM play only and the proper drag upon spinning. |
MY VW made that sound when it sucked a piece of paper into the fan. If the sound goes away with the fan belt removed, look for something that may have gotten sucked up by the fan and is under the shroud.
Bob B |
Sounds like "wooo wooo"?
Might it be this? <iframe width="420" height="315" src="https://www.youtube.com/embed/JZD-ADArwXo" frameborder="0" allowfullscreen></iframe> |
Hey, OsoMoore,
Did the dizzy fix your arcing? I must've missed the update. |
Long shot, Belt tension?
I really appreciate the input from all y'all on that challenge. (Drat, too much time spent in Texas.) So I was going to pull the belt last night, but the wife wanted to go for a drive and a movie, and who am I to say no? Hopefully Saturday morning I will have time to wash the car and check this too. I think I also need to up the idle a little bit. She's at about 700 and sometimes coughs because of it. |
My 86 makes the sam sound and always wondered what it was. I will try removing the belt and report with my findinds.
Damn, you beat me to it!!!
Another vote for the fan belt too tight here. Or a faulty alternator bearing.
Last time I installed my alternator I had the belt a bit too tight and there was a Woo Woo sound like yours. Jose |
There does seem to be a failing bearing noise in he audio background.. |
I'm with CCM911, could be alternator related, bearings and even the diodes working (or not) can make similar noises.
Run the engine with the fan belt removed to see if the noise goes away. Also with the engine off, spin the fan with one hand and your other on the housing to feel for a rough bearing. |
Whilst awaiting a CDI swap, I have taken out the alternator. Spinning on a table, there are no bad noises and things seem OK. I'm planning to put it back in and adjust the belt when I get the new CDI box.
Change of heart! Took apart the alternator partly. Removed the long bolts but haven't gotten the rest off yet (going shopping with the wife for her birthday now).
One of the brushes is significantly shorter. I'll post a picture. Does anyone sell an alternator rebuild kit, or a new brush kit? Doesn't seem that hard to work on seeing as it is just a clean-refresh effort and nothing is actually broken. |
I used these guys to source all the parts for my alternator rebuild
- Alternator & Starter Parts Wholesale |
I think the hard part is soldering/welding the brushes on with hot enough soldering tool.
You can purchase slip ring brush/holder assembly, no soldering required.
But given the HEAT level of the pulley you noted earlier I would be very suspicious of the front bearing. Where you able to find the # of years/miles your alternator has been in service? Complete rebuild kits, new slip rings, brushes, regulator, bearings, are available for under $40. |
And be sure and look closely, examine, the stator wiring support/insulators.
http://forums.pelicanparts.com/uploa...1432645644.jpg Also, here is a picture of the current length of my brushes. The long one is 1/4 inch, the short one is 1/8 of an inch. http://forums.pelicanparts.com/uploa...1432645682.jpg I can check my records when i get home. It is a Valero alternator that has somewhere between 40 and 60K on it, assuming it at least replaced during the rebuild 15 years ago. I'll have to pull out the Big Book to be sure. I see lots of kits here: Bosch - Alternator & Starter Parts Wholesale But I don't know which one is right. |
| All times are GMT -8. The time now is 07:31 AM. |
