Northern, CA
Clutch Slave Bleed Question
I've read many of the posts on clutch bleeding and still have a question. Some of the posts said it was critical to get the car level before bleeding the slave cylinder so that the bleed screw is the highest point.
I would like to use my 10 in. lift Race Ramps so that I can easily/safely get under the car to access the bleed screw.
I'll be using a Motive system to pressurize the brake master during the process.
My question is "Can I just back the car up on the Race Ramps and bleed the system once it's pressurized or is it really critical to get the car level at the front also?" That's an extra PITA I'd rather avoid if possible.
1989 Carrera Coupe
Old 05-02-2015, 05:37 PM
87 - 911
You should be fine, I've bled mine when the rear is elevated.
Watch the fluid level as you bleed, the feed to the clutch circuit is fairly high up on the reservoir.
Old 05-02-2015, 05:51 PM
