Nardi Horn Button Retaining Ring
I was changing over my steering wheel hub and was working on the project based on what the PO told me about the car... he said the car had a Momo wheel. Turns out it is a Nardi wheel. I think I have everything figured out for mounting the wheel - either a Nardi hub or and adapter - I'm going with the adapter since I already bought the Momo hub.
Last bit is that the Momo horn button retaining ring is too small
Can someone confirm for me the correct ID of a Nardi horn button retaining ring? Also, any thoughts on a source for said ring would be appreciated.
TIA,
Wayne
Wayne
1980 911 SC
1960 MGA 1600
Old 04-27-2015, 07:39 AM
By ID, I mean Inside Dimension
Wayne
1980 911 SC
1960 MGA 1600
Old 04-27-2015, 12:02 PM
Hope this is of some help - the actual diametre is 49.36mm but the four little "nubs" you can see at 3,6,9 and 12 o'clock bump that out to 55.71mm. The ID of the retaining ring itself is approx 55.5mm so the fit of the horn button itself is quite tight which is probably not a bad thing.
I'd just buy the Nardi hub/ring as it shouldn't be too difficult to off-load the Momo hub - it seems like every man and his dog want's a Momo wheel simply because everyone else has one. It's nice to see someone occassionally do something different.
Old 04-29-2015, 05:07 AM
Thanks scold! I got it sorted.
Wayne
1980 911 SC
1960 MGA 1600
Old 04-29-2015, 05:57 PM
