-   -   Fuse Panel Update (1983 SC) (http://forums.pelicanparts.com/porsche-911-technical-forum/864402-fuse-panel-update-1983-sc.html)
DavidI 05-08-2015 11:03 AM
Recently I purchased an ATF blade style fuse panel for my 1983 SC from Fred Cook. He immediately shipped it and I was very impressed with the build quality. I reviewed his included directions and ensured I understood of the process. I photographed the old panel prior to starting on the project.
http://forums.pelicanparts.com/uploa...1431103950.jpg
I carefully labeled each group of wires and crimped them as I progressed.
http://forums.pelicanparts.com/uploa...1431104082.jpg
After I removed the old panel, I found one unconnected solid gray wire that appeared to have been connected. I stripped the wire back to get fresh metal, as depicted in the below photo. It was near the #2, #3, and #4 fuse on the panel. I reviewed my photos and threads on the board to try to figure out where it should go, but no luck. Fred's included instructions indicate there is a single gray wire leading into and a single gray wire out of fuse #2 for the license plate light. I have the in and out gray wires already connected and the license plate light works. Logically, it would connect to either the in or out in fuse #2, but how can I ensure I get it right? I tested it and it does not have power to it when the lights are on, which actives the license plate light.
I am looking for suggestions. I appreciate your guidance!
http://forums.pelicanparts.com/uploa...1431104533.jpg
tirwin 05-08-2015 01:08 PM
Fog lights?
timmy2 05-08-2015 01:25 PM
Likely fog lamp wire.
DavidI 05-08-2015 03:59 PM
Should it be plugged into the top or bottom of the fuse panel? It does not have power, so I presume it should connect to the upper side. Does anyone else have two gray wires plugged into the top output portion of the fuse panel?
I appreciate the help.
