JOHN21BLACK's Avatar
915 clutch mystery
Just put new clutch kit with release bearing. I have done many over the years,but this time when I push clutch pedal it slows down my motor to a stall. Motor runs fine at idle and revs fine. Has any one had this problem? HELP!
Old 04-30-2015, 09:13 PM
It comes back out and then you will be able to figure out why.
Porsche 2005 GT3, 2006 997S with bore-scoring
Exotic: Ferrari F360F1 TDF, Ferrari 328 GTS
Disposable Car: BMW 530xiT, 2008 Mini Cooper S
Two-wheel art: Ducati 907IE, Ducati 851
Old 04-30-2015, 10:19 PM
pors1968's Avatar
What is part number pressure plate.
Old 05-01-2015, 03:25 AM
I know on a G50 that if you put the clutch disc on the wrong way, it will catch on the guide tube and lock. Not sure if this can happen with a 915. Hopefully, better minds than mine will chime in.
Christopher Mahalick
1984 911 Targa, 1974 Lotus Europa TCS
2001 BMW 530i(5spd!), Ducati 900 SS/SP
2006 Kawasaki Ninja 250, 2015 Yamaha R3
1965 Suzuki k15 Hillbilly, 1975 Suzuki GT750
Old 05-01-2015, 05:55 AM
Member 911 Anonymous
DRACO A5OG's Avatar
Before you drop again. Have a helper press the clutch as you feel the top of the fork and release bearing via the inspection hole on top of the gear box to see if it moves fore and aft.
'85 Carrera Targa
PCA/POC
Old 05-02-2015, 01:16 AM
SoyRacer's Avatar
I had a car come in many years ago with this same set of conditions
The disc was in backwards.
But that was that car
1973 Porsche 911 RS
1981 Porsche 931 Euro-Intercooled-GT
1984 Porsche 911 Euro Carrera widebody
1987 Porsche 924s Rallye Spec
Instagram: @soyracer
Old 05-02-2015, 06:16 AM
I did use a camera threw view hole and saw top of fork and bearing move front to back. Have not tried it with motor running to see if bearing is spinning. Trying that next.
Old 05-02-2015, 05:42 PM
you guys got me thinking about the disc being backwards. Which way does it go in? I thought cone side faces foward
Old 05-02-2015, 05:53 PM
The cone faces away from the engine, so it does face forward of the car
Old 05-02-2015, 06:16 PM
well just looked with camera and disc is facing foward. I could tell by the rivits on disc. they are covered up by disc. If it was backwards the rivits would be in clear view.
Old 05-02-2015, 06:55 PM
pressure plate part # 915.116.001.27
Old 05-02-2015, 07:10 PM
kodioneill's Avatar
Year/model?
1974 sahara beige 911 targa
1982 chiffon 911sc
1985 prussian blue metallic carrera
Old 05-03-2015, 05:27 AM
Originally Posted by kodioneill View Post
year/model?
. 1976 911s
Old 05-03-2015, 07:17 AM
1976 911s 2.7
Old 05-03-2015, 07:20 AM
this is a pic of release bearing on guide tube. Whats the distance from bearing to bottom of guide tube? I felt with my finger and it feels about 5/8 in. Clutch engages about half of that.
Old 05-06-2015, 03:17 PM
Here are some pics of motor. Just got it back in.
Old 05-06-2015, 03:31 PM
clutch works fine now. shifts into gear easy. thanks for all the help
Old 05-07-2015, 06:53 PM
Uncle Enzo's Avatar
What was it?
1976 911S
MidYear Fever is alive and well.
Old 05-07-2015, 06:55 PM
Well, what was the problem, and the fix?
It would be nice to know so that the next guy can benefit from all the help. You will not be the only one to ever have this problem...
Old 05-08-2015, 07:13 AM
tobluforu's Avatar
Great looking motor.
I guessing he was pressing on the brake, not the clutch. Until he tells us, that's my guess.
Old 05-08-2015, 08:36 AM
