stv951's Avatar
Building a 3.2 twin spark high compression SC. 964 cams dont fit with stock oil coole
Hello.
I am in the process of building a fast road 911 SC engine.
Ive installed 3.2 pistons and cylinders with 10.3 compression and carillo rods
Ive also converted the heads to twin spark
This will be fed through a set of new 46mm PMO carbs
Ive also got a nice set of 964 cams but i now see that the original engine oil cooler does not fit.
Whats the solution to this ?
Old 05-20-2015, 12:52 PM
I would rather be driving
jpnovak's Avatar
remove the power steering drive from the PS cam end and then plug the end of the cam tower as normal.
Old 05-20-2015, 01:22 PM
