non-whiner
mreid's Avatar
THE balljoint nut socket
These show up on eBay now and then and they are indestructible!
http://pages.ebay.com/link/?nav=item.view&alt=web&id=151515618276
You can use an impact gun with this tool to remove the nut unlike others. Best $60 you will spend.
No affiliation, just pointing out a great tool!
"Too much is just enough."
Old 05-10-2015, 02:44 PM
sugarwood's Avatar
I am going to try this soon.
I've seen others posted for $12 and $20.
Does this one for $12 work just the same?
KD Tools 4 Lug 4WD Spindle Nut Socket 1 2 Ton GM Dana 50 3937 | eBay
Or this for $20?
OEM 25965 1/2-Inch 66.5 by 80mm Front Wheel Bearing Locknut Socket - Tire Iron Set - Amazon.com
1986 Bosch Icon Wipers coupe.
Old 05-10-2015, 03:28 PM
French Import
zippy_gg's Avatar
Originally Posted by sugarwood View Post
I have this one and it worked kinda OK but not great. It tends to slip because the width of the teeth does not match the castellated nut.
I could not use it for disassembly (the front rack was on my bench) but had more success during reassembly when the rack on the car and a jack underneath to add upward pressure. Still not the ideal tool because it is only approximately the size you need.
Gilles & Kathy
Happiness is not having a Porsche in the garage... Happiness is having a Porsche on the road!
86 Porsche 911 Cabriolet, 2011 BMW 1200RT, 03 Saab 93 Cabriolet, 06 MB E350 Estate
Old 05-10-2015, 03:50 PM
Spiderman
Jesse16's Avatar
That eBay tool is the same one our host sells for $55. Our hosts is a quality tool. Worked perfect for me using the "jack for pressure" method. I actually borrowed from a forum member so just a little shipping cost and beer money.
Midnight Blue 08 Cayman S, Fun/Track
Black 12 VW-GTI, work
Mexico Blue 87 Carrera, sold, sad, not enough garage space.
Old 05-10-2015, 04:15 PM
TheSt|G's Avatar
Don't get the junk >$20 chinesium version, will do more harm than good. The Porsche specialty tool for the job costs ~$55 if I remember correctly, and is beautiful. I used it for both dis-assembly and reassembly using the jack method.
1985 911 3.2 Carrera Coupe - Constant Project - 2550lbs
2005 E46 M3- Daily Beater - 3350lbs
Old 05-10-2015, 06:10 PM
