Engine install today...questions
Aloha, I have several questions, but I'll just ask the ones about the physical install now. I think I read the clutch cable and the throttle rod go above the trans mount plate, correct? I clocked my new hi torque starter to the 4th position as I have read. I installed it with the engine out, does this look right? will it fit in this orientation?
http://forums.pelicanparts.com/uploa...1431258910.jpg Thanks in advance. Cheers, Mike. |
Your correct on cables and linkage above trans mount. As far as starter. I install mine after install.
OK thanks. I think you are right. I'll remove the starter. No sense in having to stop the install because the starter is in the way...DOH!
Cheers. |
I always install the starter first and have never had any problems with it.
I always install the starter first, but mine it clocked so the battery stud is vertical.
http://forums.pelicanparts.com/uploa...1431263235.jpg |
| All times are GMT -8. The time now is 01:39 AM. |
