bennysc1
Wheel spacers - what size wheel stud
Any help here would be greatly appreciated. I have 1983 SC Coupe with 16 X 7 on the rears. Looking to add 17MM wheel spacers. Does anyone know what size wheel studs to use? I am using closed lug nuts and the wheels are factory Fuchs. Thank you.
Old 05-13-2015, 05:43 AM
I'm not sure what is standard on an 83, but for my '73 it is a 45mm stud. I added 14mm spacers and used a 60mm stud. (45+14=59) They were difficult to find. Finally got them in jolly old England. Be prepared to roll your fenders.
Tom
Old 05-13-2015, 07:31 AM
Paper Member
Standard length on an SC is 45mm also. Add 17mm and you're at 62. 66mm is available but may be too long for you.
Enemy of the State
Brandolini’s Law: It takes hours more time, research, and writing to debunk misinformation than it takes to spread it.
Old 05-13-2015, 07:37 AM
Studs
The factory Verbus studs in the 66mm length should be the best. These were used with the factory 21mm spacers. Check my post using the key words: "spacers and long studs"
Old 05-13-2015, 07:38 AM
Ova Day
msterling's Avatar
66mm is about the max you can install without doing major disassembly of the rear hub. If you remove just the caliper, disc and the parking brake adjuster you can just sneak the 66m studs into place. I have 14mm spacers and the studs are a bit too long to use with the factory aluminum nuts on Fuchs wheels. I use open steel lugnuts as they are more durable anyway. I doubt that you will have fender clearance issues unless the rear height is set very low.
88 Triple Black 911 Carrera Cab, ex Garage Queen
05 BMW E46 M3
21 Tesla Model 3 LR
08 BMW 328xi
15 Ford F150
Old 05-13-2015, 09:25 AM
