Senior Member
Wheels for 70E
I have the 5.5x14's which were standard for my car from the factory but would like to upgrade a bit. Was leaning towards 6x15's all around. Without any mods, will 7X15's fit in the rear?
Chris
1988 911 Carrera Targa (driving project started JAN 2022)
1970 911E - Long since gone
1972 911 Targa - gone
1987 911 Carrera - gone
Retired FA-18C Driver
Old 11-05-2002, 03:26 PM
Crusty Conservative
silverc4s's Avatar
It depends on the tyre size, and your specific car's clearances. Do a search on tire and wheel combinations for early cars or some such, and you will find a lot of dialouge has been done in that vein...
Bill
69 911 T Targa, 2.4E w/carbs (1985-2001)
70 911 S Coupe, 2nd owner (1989- 2015)
73 911 T Targa, 3.2 Motronic (2001- )
Old 11-05-2002, 03:32 PM
Stay away from my Member
campbellcj's Avatar
I like 6x16's on the early (stock-bodied) cars. You run 205/55 tires. Factory SC-Carrera front size for many years, so the wheels and good tires are readily available.
The 6x15 'deep' Fuchs are the correct vintage wheel, and should also work fine with 205/60 or 195/65 tires (185/70's are essentially NLA now except for a few CW stashes here and there.)
Chris C.
1973 914 "R" (914-6) | track toy
2009 911 Turbo 6-speed (997.1TT) | street weapon
2021 Tesla Model 3 Performance | daily driver
2001 F150 Supercrew 4x4 | hauler
Old 11-05-2002, 05:42 PM
Bandwidth AbUser
Jim Richards's Avatar
Hi Chris,
I was looking at Bruce Anderson's book and he shows a recommended wheel/tire combination for your car of 7x15 with 205/60-15's. Of course there's no mention of whether or not rolling your fenders is required. He does say that you need to be careful of the wheel offsets to make sure they'll work. Hopefully someone else on the board will address that.
Regards,
Jim R.
Old 11-05-2002, 05:52 PM
Senior Member
I am wavering on the 15v16" debate. One of the pro's for the 15" wheels is that they seem to be a bit more reasonable to buy. (That and being somewhat more "correct") But, I am not building a concours car, just want more filling out the wheel cutout. I've got a set of 6x15 cookie cutters with Pirelli's I may throw on to see how it looks and rides, but want to go with fuchs for sure. Of course now Ill need to get rid of these wheels, was going to use them for track wheels, but think Ill go steel instead.
Jim-was looking at the same advice from Bruce, but I think I'd need to roll my fenders and am not really interested. If I'm going to go that route I'd be better off going RS flares and getting some REAL wheels back there.
Chris
Old 11-05-2002, 06:39 PM
addictionMS's Avatar
I have a 1970 T and I currently have 205/55/16 on the front and 225/16/16 on the rear, you have to roll the rear fenders and put a little camber on it, but they seem to fit. I am transplanting a 3.2 and 915 so I have yet to drive on these tires.
Jim
Old 11-05-2002, 06:46 PM
Bandwidth AbUser
Hey Chris,
Another consideration is the availability of tires to fit whichever wheels you go with. I've seen some threads covering this in the past; however, you can probably get a good feeling about this by contacting Tire Rack.
Regards,
Jim R.
Old 11-05-2002, 06:47 PM
70flatsix's Avatar
Wheels and tires for 1970 911E
Chris,
I've got 6" x 15" fuchs on all four corners with Michelin Pilot 205/60/VR15's. Even with new rear shocks, when my 2 kids (ages 13 and 11) are in the rear seats, I experience mild rubbing on the left side. Hope this helps. Good luck!
Rock
70 Irish Racing Green 911E Soft Window Targa Spyder
Delaware PCA Member - inactive
Old 11-06-2002, 05:25 AM
twin plugged targa's Avatar
I have 16's 6's and 7's but the PO put 205 tires all round?
At 1st the tires did rub causing the paint to bubble on the new paint
Now the susp. is set up right nad no rubbing.
I would reccomend 16 6's all round but I may hang on to the 7's as I plan to do Carrera flares on the rear later.
rgds ben
AKA "86ragtop" 1986 911 Carrera SOLD 11/2001
1984 Carrera 3.2 IROC RSR look
Old 11-06-2002, 05:35 AM
Senior Member
Thanks for the info guys, based on what I'm hearing seems I'll plan on the 15" wheels and stick with 6's. I've got new (2-3 yar) shocks all around so hopefully Ill be able to put good rubber in there as well.
Chris
Old 11-06-2002, 06:35 AM
arrivederci's Avatar
Anyone put 7's and 9's on an early car?
I currently run 15x6s with 205/55 R15 all the way around on my stock bodied '72. This winter, I'll be adding RS flares. I want to move to 16's because of gearing and better track rubber sizes. Does anyone know if I'll be able to squeeze the 16x7 and 16x9 from my '87 930 on the '72? I threw a 16x7 on the front and things looked really tight, even with a 205/50 tire on it. See a picture at:
http://members.rennlist.com/jpinkert/Side%20View%20-%20Straight%20sm.jpg
http://members.rennlist.com/jpinkert/Top%20View%20-%20Straight%20sm.jpg
http://members.rennlist.com/jpinkert/Side%20View%20-%20Turn%20Left%20sm.jpg
http://members.rennlist.com/jpinkert/Side%20View%20-%20Turn%20Right%20sm.jpg
Thoughts? Mods required for more clearance?
- '72 911T
- '81 911SC Euro
Old 11-06-2002, 06:43 AM
