What's the widest you can put on 17" 9" wide wheel?
Pics also well seen
Eva
You'll reach the limit of the fender well before the wheel.
What car/fenders in question?
'78 SC Targa ~Brynhild~ Insta: @911saucy "The car has been the cave wall on which Industrial Man has painted his longings and desires." -Eddie Alterman- |
newb.
tread width wider than rim width isn't positive for handling, for what it's worth.
keith '75 RS/RSR-look | '73 CB750 | '70 TD250B r gruppe #436 |
Depends on the tire. Some can handle a pinch better than others, due to differences in sidewall construction.
For example, the BFGoodrich Rival & Rival-S have a stiff sidewall profiled to handle working on a narrower rim, and they seem to handle it well. A 275 on a 9" is within their recommended range, I've seen as wild as a 255 on a 7" (huge pinch) actually work surprisingly well. Not ideal, but it works. I wouldn't recommend it at all on tires with softer sidewalls. A pinched tire sets the sidewalls like this: /____\ Which doesn't support the tread optimally when cornering. Best practice if possible is to match tread width to wheel with. Or better yet, match wheel width to your desired tire width. Remember, it doesn't put more rubber on the road to have a wider tire. It's not perfectly linear, but how much rubber touches the road is limited by pounds per square inch, which you are likely not changing. A wider tire only changes the shape of that patch. If you're just doing it for fashion purposes and don't care about performance at all, go nuts.
Matt - 84 Carrera |
Spiderman
On my 87, 255/40 Falkens have a nice straight sidewall on my 9x17" Fikse's. They just fit and don't hit in my experience. Are very close inside and out.
Midnight Blue 08 Cayman S, Fun/Track Black 12 VW-GTI, work Mexico Blue 87 Carrera, sold, sad, not enough garage space. |
Ova Day
I have 255/40-17 Hankook RS-3 tires on my 17x9 Euromeister wheels on the rear. 1988 Carrera. No rubbing. Tread width is 9.6". I have room to use 14mm spacers without a problem.
88 Triple Black 911 Carrera Cab, ex Garage Queen 05 BMW E46 M3 21 Tesla Model 3 LR 08 BMW 328xi 15 Ford F150 |
I was thinking about going 275 on the rear
![]() Here are some 275's
63 356 So Called Outlaw 76 930 |
And how does it ride?
I want to go with some wide slicks on the back |
What size torsion bars? Sway bars, struts etc.
Ova Day
275/40-17 would be a pretty tall tire. 25.7" or so. It would change gearing to taller. SC/Carrera rear fenders allow pretty fat tires. I only see a few choices for that size. Bridgestone RE760 is a pretty good tire and they have the sizes to fit the front. 215/45-17 or 225/45-17.
Eva
FWIW, I have Nitto 255 Rears under the rear of my SC and they fit without issue. I was actually considering a 5mm spacer but don't want to change the studs
Pretty common. I started running those back in 1997.
Mike 1976 Euro 911 3.2 w/10.3 compression & SSIs 22/29 torsions, 22/22 adjustable sways, Carrera brakes |
Almost all tire retailers will list "specs" for tires. Tire have ab acceptable run range as well as a "measuring" rim which is used to determine all the other numbers like section width, sidewall height etc. So how wide a tire??? Depends on the brand but normally around 255-265 section width.
Hope this helps.
'75 Carrera, It's stock, I swear, scouts honor! |
Not a great pic, but you can get the idea...
