Turn Signal Issue on 1988 911 cab???
All turn signals work fine until I turn headlights on. While the both sides continue to work, the left side all flash very fast. Could it be the flasher even though the right side are not affected? Where should I look first?
No ideas?
Likely a bad bulb in the circuit someplace. Are all the marker lights and such working? Also bets to check and clean grounds. Do you have a Bentley manual or a wiring diagram specific to you MY? Pelican has them online.
| All times are GMT -8. The time now is 04:37 AM. |
