-   -   930S Wheel and Porsche Crest (http://forums.pelicanparts.com/porsche-911-technical-forum/86563-930s-wheel-porsche-crest.html)
Rot 911 11-06-2002 08:40 AM
Ok I got the wheel and the crest yesterday. I see the crest has like a 1/2" long pin on the back of it. Now my question, what method have you guys used to attach the crest to the horn pad? Did you drill a hole and push the crest in by the pin or did you cut the pin off and glue the crest to the horn pad? Inquiring minds want to know!
Rot 911 11-06-2002 10:37 AM
Come on, I know somebody on here has the answers I need!!!!
steve911 11-06-2002 11:36 AM
Kurt--
sorry, can't answer definitively, as mine came with the crest already attached. I seem to recall a thread saying the crest attaches with a speed nut (like the hood emblem).
hope this helps
widebody911 11-06-2002 02:50 PM
I'm in the same boat - got mine yesterday.
Halm 11-06-2002 03:10 PM
Seem to recall from the original thread Wayne saying that Pelican was going to do a Tech article on installing the crest and the wheel..
DByers 11-06-2002 03:35 PM
Installed my wheel and the crest is still in its little baggy waiting for me to figure it out. There is a tech article already about installing the wheel, but does not say anything about the crest install. I am sure I will afix the crest someday soon, but for now I am liking the wheel without it. Maybe a good leather/saddle shop could emboss the Porsche crest in the horn pad? Hey we must be the 4 lucky winners ( Halm, Kurt V, widebody911)of the email response contest!;)
MAS956 11-23-2002 10:59 AM
bump
Did this question ever get answered? I have the same issue.
Thanks,
adamsbomb 11-23-2002 11:51 AM
I am not sure, but I seem to recall it saying somewhere to drill it. However, how do you drill through the leater without a problem. I was just about to order mine when this cooler issue came up, (Got it lined up for my birthday from the wife though;) )
buttjoint 11-23-2002 12:03 PM
Same problem, I got ahold of sam @ pelican and he is sending me the keeper that goes with the crest. My problem is the horn, It wont shut-up:(
buttjoint 11-24-2002 08:35 AM
Got the horn fixed and recieved the keeper for the crest. The only problem is that the stud is not long enough. I drilled a hole same size as the stud added a drop of silicon done deal
79930 11-25-2002 08:58 AM
I am still waiting for my wheel and crest, but I would like to have the answer before I begin installing mine.
Kevin
82SC 11-25-2002 01:50 PM
you can use a speed nut (it is the same as the ones that hold your emblems on the hood and trunk)
or use a tiny bit of adhesive
and yes you do drill a hole
If I were going to use adhesive, Id just dremel the pin off and glue it on
MJ
philfran 11-25-2002 03:21 PM
I looked like the pin was not long enough so I just used a little silicone and stuck that sucker on.
Wayne 962 11-25-2002 03:26 PM
You need to drill a hole, and stick it on there. I am going to do a tech article, but I've been a bit busy lately with other things on the site...
If someone wants to volunteer to write a tech article, I would take that as a nice thank you for offering these wheels at such a great price!
-Wayne
