| brian hill Join Date: May 2015 Location: winnipeg
				porsche 911
			I have a 1970 porsche 911t it is serial no 9110101856 engine no 696006 is that correct ? I cannot find an engine number like that. it is a german import.
|  05-18-2015, 01:12 PM |
| Registered |
			Engine is 7 number your missing a number after the 6..96006
|  05-18-2015, 06:04 PM |
| Registered Join Date: May 2003 Location: Winnipeg
			Welcome Brian! Yes, you're missing something. Assuming that you have missed the second digit, a 1969 engine could be: 619 xxxx 629 xxxx 639 xxxx I believe the '70 engines would be: 610 xxxx 620 xxxx 630 xxxx Tim K | ||
|  05-18-2015, 07:05 PM |
| Registered Join Date: Oct 2005 Location: Capistrano Beach, Ca.
As others posted, a digit is missing.  However, the first "6" in the last four digits indicates the engine is a US spec T.  Since the car was a German import and the engine is likely a 69, not a 70, it's fairly certain it is a replacement regardless of the missing digit.  Posting the missing digit will confirm which 69 engine was installed.
				__________________ L.J. Recovering Porsche-holic Gave up trying to stay clean Stabilized on a Pelican I.V. drip | ||
|  05-19-2015, 06:33 AM |
