Reversed battery connection - engine smoking
Dumb ass move of the day!
I hooked up the battery in reverse - the engine attempted to turned over and lots of smoke and burning smells came from the engine compartment. I have a positive ground 55 MG so I followed that routine and but on the wrong car!! Anyway I have removed the battery and decided to ask the Pelican experts what might happen when I reconnect correctly. Is there any risk of further damage and/or fire? I am assuming fuses/relays, the starter and other parts may need replacing. Looking for any suggestions as I crawl back into my garage ashamed of my incompetence. Thanks, Tim |
I'm far from an 'expert' but the first place I'd look is at your alternator. Those things have diodes that demand that the "blue-stuff" goes in one particular direction if everything is hooked up OK. Yours wasn't so they might be affected. As well you may have fried your starter.
But what the heck. With all those possibilities, why not hook the batteries up correctly, have an assistant with a fire extinguisher standing by and give her a shot. :eek: Good luck, Tom |
Does the starter turn the engine backwards, when polarity is reversed? If so may be mechanical problems too. Hope not.
Good luck, Dave |
I would disconnect the alternator before you hookup the battery again - the alternator diodes, as suggested above are most assuredly toast - don't want to do more damage to alt and don't want the smoke to turn into flames. The starter most probably did turn backwards - my guess and only a guess is the the starter did not engage the motor - I'm not sure how these starters engage the flywheel. If it were your MG I can tell you reverse polarity would not engage the starter into the flywheel.
Good luck and, if it helps, don't feel too bad and if misery likes company, I did the same thing on my MGB and toasted my alternator - the diodes popped like popcorn. |
I would be concerned with the alternator and DME brain.
As well as all the possible damage that others have mentioned, I think you will be incredibly lucky if you haven't fried your DME computer with reverse polarity!
Any 'so-called' electronic components might be/ will be fried.. Basic wiring should not be affected..
Radio as well.....
The starter should be fine, everything else not so much. The most expensive component will always blow to protect the least expensive component. I agree though, disconnect the large alternator cable at the starter motor and see what still works and what does not. Everybody deserves some luck. When I did this on my boat I only killed the depth sounder, the CDI etc was fine.
Best of luck and don't beat yourself up too much, stuff happens. |
your not the first.
alt and DME would be my first concern. diodes can take reverse polarity, that is there job, the regulator may not like it. you can dissconnect the alt at the starter. if the DME is fried putting power to it wont hurt it any more than it already is. yea that stupid british lucas crap....just had to be different |
OK, I'll fess up.... I just did this also ! the winter was tough on my battery,so got a new one.
Wasn't paying attention... hooked up wrong... got smoke... altenator fried !! I did NOT have any other issues ! I did, however, have a hard time getting a altenator. Pelican was on backorder with them and most other suppliers were as well. I did get one, but it took awhile. Best of luck with this ! |
Tough luck Venezia and chuckr.
What year was your chuckr? glad it worked out. Venezia - You might be ok (outside of the ALT). Do a search here, some beat you to it and have done it before and came away with minimal damage. Your cables behind the ALT may need attention, check all of your fuses and the wiring around them. Some stuff that might still work might fail later, so watch for that. |
I have an 88 911. Pelican did have a new one ,ouch !! but I wanted rebuilt.
This is how I subscribe so I can see the pictures that will follow. |
Thank you all for the feedback.
I reconnected the battery, correctly this time and as soon as I screwed down the quick release, the engine began to turnover, including exhaust from the pipe - all this without a key in the ignition. I can switch the quick release on and off and the starter begins to turn. Fuses and relays are all good but 'Houston, we have ignition without a key' which isn't the way. Not sure what the next step is but it looks like I will get the 911 to my local expert since I lack the skills to diagnose the problem. Best, Tim |
I think you can buy the diodes/heat sink and the diode triple at several places online (with a search). I want to see if the windings are cooked. This alternator has 6 parallel paths of two diodes connected in series. I wonder if they held on long enough to limit the reverse voltage to two diode drops on all the expensive stuff. http://forums.pelicanparts.com/uploa...1432155158.jpg |
remove the 14 pin connector at the relay panel and see if it does it again. if it does NOT then the problem is in the engine wiring harness.
| All times are GMT -8. The time now is 04:02 PM. |
