Axle Boot Identification
My mongrel 1970 911 has a set of axles fitted that nobody seems to be able to identify the boots and I was hoping that someone here could identify the year. So far I have sent the axles to one of the usual suppliers and they had nothing that fitted. Would you guys mind taking a look and suggesting what I need to order?http://forums.pelicanparts.com/uploa...1432146892.jpg
http://forums.pelicanparts.com/uploa...1432147005.jpg http://forums.pelicanparts.com/uploa...1432147015.jpg |
Take the boot clamp off and clean the area of the boot that was clamped to the flange. There should be a part number there.
They could be: 901.332.293.12
I agree, the cv's look like the 108mm ones, I just replaced mine with the ones suggested by Winders 901-332-293-12-M60, they are tight but fit fine!
Everyone - thanks for the advice.
Did you take the clamp off and check for the part number? If yes, what did you find?
Update?
| All times are GMT -8. The time now is 04:17 AM. |
