Currently sitting at 16-1 and we all know who the 1 is. There's your answer!
I've contacted the EPA in the past and asked them for the empirical study which supposedly concludes it is not necessary to replace non barrier hoses with barrier hoses. Their response: " gee, we have no idea", and "gee, we have no idea whom changed the text in the EPA website"
Understand that most passenger vehicles have less than 12 feet of rubber ac hose, in most cases the lines are metal. And, today, most refrigerant lines are metal for a reason, other than quick installation by a robot, .... metal does not permeate refrigerant gas as easily as rubber. I believe this previous post sums it up: http://forums.pelicanparts.com/porsche-911-technical-forum/750353--non-barrier-hoses-do--leak.html#post7447688 |
By the way, one of the major producers of refrigerant hose in the US noted there will be a major price hike this summer. They have not concluded as to much of a % the costs will go up, kinda odd considering the cost of oil is down, wages are down, lol.
As I am about to replace the old rubber, should I consider having metal lines made? |
Ziggy,
Yes. Of course consider metal if you are handy. As I stated, and the auto industry has moved to, metal leaks less than non barrier hoses. Pro's: Less leakage. Lighter weight (aluminum). Con's: More time to do the job, and more tools required. If you don't get your braze joints correct, you got leaks Potential for corrosion. So, if you want to delete the source of common permeation (leakage) through old fashion non barrier hoses, you have 2 choices: A) Barrier hoses, either buying a set, or having them made for you, and some buy their own hose crimper or borrow one. The hose PP sells individual barrier hoses and complete sets. B) Make your own metal lines. Look up Jim Sim's in the various threads, he's done metal lines, and as well he has used our barrier hoses on an earlier car. PS: just ignore willy. |
Should wwest be banned permanently? Yes or no |
wow, that did not take long. must be a record.
but...but...but... what about that trinary switch???:D
I'm about to venture down this path and have decided to try the DIY route.
I bought a hose crimper from amazon, and will try it out once I get back from vacation in a couple weeks. Check out a pic at: http://forums.pelicanparts.com/porsche-911-technical-forum/865196-new-flux-capacitor-aka-ac-hose-crimper.html So far I've only planned out materials to replace hoses from the compressor to the R/D, as a "phase 1". More to follow. Cheers Nathan |
I replaced the liquid line on my P-car with copper tubing - never have to worry about it ever leaking again. Hadn't done the suction line yet because it hasn't leaked but when it does it will be replaced with insulated copper tubing
Dave |
- Manfred |
| All times are GMT -8. The time now is 05:48 PM. |
