Targa badge
Hi there
Time to spray the tanga bar on my 82 SC. Does anyone know how the 'targa' badges come off? Reckon I can make a better job of it if I remove these first, even though they are the same colour.
Many thanks for any help.
kevin
Old 05-27-2015, 05:52 AM
Justin@Athens's Avatar
Send a message via AIM to Justin@Athens
It is a real pia. The whole bar has to come off. There are two nuts under each wheel well. Then you will remove the weatherstriping. Under the weatherstrip are a series of phillips screws (maybe 10-12).
I think on your car you are going to need to remove the charcoal canister under the passenger's wheel well in order to get to the nuts on that side. Run a search, this has been asked before. Probably some pictures floating out there.
1990 964 C4 Coupe & 1991 964 C2 Coupe (current)
1989 911 Targa (sold)
1996 993 Cab. (sold)
1999 x2 Boxster (sold)
2006 Cayman S (my daily)
Old 05-27-2015, 06:06 AM
Eva
911SauCy's Avatar
As do the 14 phillips head screws around the front of the bar, which, you wont find without removing the seal.
'78 SC Targa ~Brynhild~ Insta: @911saucy
"The car has been the cave wall on which Industrial Man has painted his longings and desires." -Eddie Alterman-
Old 05-27-2015, 06:25 AM
Thanks guys. The plan was a quick tidy up, with a view to sorting it properly at a later date. I'm thinking I will leave them on......for now anyways
Kevin
Old 05-27-2015, 07:02 AM
you will want to order a set of the plastic rivets/plugs and maybe a set of the plastic screws for the ski rack mounting points. Doubtful the old plastic bits will survive removal.
1982 911 Targa, 3.0L ROW with Webers
Old 05-27-2015, 07:15 AM
