911 front brake part I.D. help
1 Attachment(s)
I'm installing early M struts/calipers on my car right now. I bought all new brake lines, banjo fitting and washers. Washers to fit each side of banjo fitting are different sizes. Per the attached pic, which washer (large or small) goes toward the caliper? I've test with and it will fit either way. I'm guessing the larger washer goes on first, then banjo fitting, smaller washer, then through bolt. Just want to do this right the first time.
John |
1 Attachment(s)
same parts......just the whole thing
1 Attachment(s)
Yup you have it right
Thanks!!
| All times are GMT -8. The time now is 05:29 PM. |
