darnellsgarage
swb axle stub install?
I've searched the threads, and I don't see that anyone has had trouble re-installing the axle hubs on an early car ('66 911). I cannot get the axle stub more than barely engaged on the splines. It certainly is not nearly enough through to get the axle nut on it to pull it through.
I froze the axles, and put a bit of heat on the hubs. Any suggestions? Is there a puller that can be used?
don
Old 05-30-2015, 08:33 PM
