Stop thinking. Let things happen. Be the ball.
<iframe src="https://www.youtube.com/embed/sWH811TcckU" allowfullscreen="" width="560" frameborder="0" height="315"></iframe> |
I always keep an old car speaker around to magnetize screwdriver tips. Just scrape the end on the speaker magnet a few times and bingo, magnetic screwdriver.
I saw Kroil penetrating oil mentioned already but how about home made penetrating oil.
I learned years ago that 50-50 mix of plain ATF fluid with Acetone makes excellent (possibly the best) penetrating oil for stubborn bolts. I use a small paint brush to apply. |
I trien ATF and Acentone. How do you get the two to mix?
Cigar old skool Smoker to find those pesky Vacuum Leaks. :D Wifey hates it, oh well.
I pulled out the intake manifold on my BMW X3 a couple weeks ago to replace a leaky gasket. Lots of nuts, bolts & connections to deal with.
To keep from dropping a fastener into the engine's black hole, I always used a small dab of black weatherstrip putty on the end of the socket or screwdriver. That stuff is really sticky. It saved me in many tight situations. Much better than trusting a magnetized tool. |
I store fasteners for a job where they were removed from so they do not become misplaced. Remove a wheel? Lug nuts go back on finger tight while wheel is removed. This keeps the project organized and prevents you from mixing hardware when you have a lot in the shop. Applies to all kinds of hardware...
You need to shake or stir. Here's the article:
http://forums.sohc4.net/index.php?topic=20131.0 Quote:
^ Interesting! I'm not sure I would use one of those compressed air cans with acetone. I have one, but use it for rubber lubricant. I spray the rubber parts of my equipment such as boots, over ride snubbers, etc with it.
Tighten the coil in the clamp before installing. Don't have to fuss with the mounting bolt in the way.
1) Pay someone who knows what they're doing
2) There is no 2) |
Searching for a parasitic current drain:
(Most people don't believe this works, but it does and it's fast). To see if a fused circuit is carrying current, measure the VOLTAGE across the fuse. Yeah I know, it sounds goofy. If there is no current flowing the voltage will be 0.00 volts. If there is current flowing, the voltage across the fuse will be approx. 0.03-0.15 volts, depending on the fuse and the current. If you find voltage across a fuse of a circuit that you believe should be quiet, then you have at least found the offending circuit. Not all circuits are fused, and it only localizes to the particular circuit, but the method is fast, does not require disconnecting anything or a special current meter. Good luck, Dave |
As my other transsexual Australian acquaintance says, "If you want it done right, write a check." |
| All times are GMT -8. The time now is 04:00 PM. |
