Super Moderator
cstreit's Avatar
Good CO level for emissions?
Gang,
THanks for a very nice Pelican member I am borrowing a Gastester to try and get my 930 in line for emissions tests.
What is a good CO to shoot for? 2%?
Anyone know the Illinois maximum?
Thanks,
chris
Chris
1996 993 RS Replica
2023 KTM 890 Adventure R
1971 Norton 750 Commando
Alcon Brake Kits
Old 11-08-2002, 10:07 AM
clamp the hose from the air pump and disconnect the oxy sensor plug before setting the CO. set it to 1.0%, and reattach the oxy sensor and unclamp the air pump hose and then see what you have. if the air pump and oxy sensor are still there, the CO at that point should be barely discernable.
206 637 4071
Old 11-08-2002, 10:17 AM
Super Moderator
cstreit's Avatar
John,
I should have clarified, this is a Euro 930 with no air pump or O2 sensor. I got the car to run at about 1% at idle (not running WELL mind you) and 3.5% at 3000 RPM.
We use rolling dyno tests here in IL....
Now, the next question, assuming I pass emissions, where do I set it back to for OPTIMUM running...
Chris
1996 993 RS Replica
Alcon Brake Kits
Old 11-08-2002, 10:27 AM
beepbeep's Avatar
I don't know about your laws, but here in sweden we measure CO @ idle for old cars.
I drive euro 930's w/o air-pump, lambda or catalyst and i got 0.1% CO @ idle on emission test. Make sure you test it with propperly warmed up engine as i failed test first with 5.5% CO and "lukewarm" engine...
Thank you for your time,
Old 11-08-2002, 01:01 PM
I would try the test at 1% then fatten it up to 3% for the rest of the year
Dean
911 SC turbo, 3.0L 930 motor, G50, 930 brakes, DTA EFI, 352 RWHP DynoDynamic dyno,
Old 11-08-2002, 05:29 PM
the cruise part of the test usually is what fails you. you can always try the plugged injector route. the cylinder becomes an airpump and lowers emissions quite a bit.
206 637 4071
Old 11-09-2002, 01:18 PM
