-   -   Early transmission mounts: Solution? (http://forums.pelicanparts.com/porsche-911-technical-forum/86817-early-transmission-mounts-solution.html)
RallyJon 11-08-2002 09:05 AM
Every discussion I read on this topic has the same non-answer. :confused:
What is the upgrade path to installing "clubsport" or solid transmission mounts on an early car with the pressed-in mounts.
1) Can the stock mounts be pressed out of the crossmember and replaced? If so, who makes/sells higher durometer or solid replacements?
2) Can a later crossmember with replaceable mounts be swapped in? Does it bolt right up or are there issues?
3) Does some racing shop make a complete aftermarket replacement?
Seems to me the world must be running out of supply for the "find a used replacement in good condition" solution someday...
