Super Moderator
Please help, failed emissions again...
Well I failed the emissions test....
Had CO set to 0.9% at idle, and the CO and HC were better, but still failed. CO was 85.1 where pass is at 60.0 (it was 218 b4) HC at 5.4 where pass is at 2.00 (was at 7.16 before) Unfortunately the testors out here use a measurement that no wrenches have access to, so it's impossible to test it before going in, plus they use a dyno, futher impossible! Car is a Euro 930 with no air pump, cat, or O2 sensor... *sigh* I tried leaning it a little more and the CO actually went UP! Any ideas from the brain trust?
I have a 79 930 and had the same problem. I went to Autozone and bought a bottle of Berryman's "Emissions Pass Protection". It's a 15 oz bottle to mix with your gasoline. It also worked on my 1986 Trans Am. So I'm a true believer. Hope this gets you passed the SmOg NaZi'S.
-BILL
"If you're not living on the edge, then you're taking up too much space." My 1979 930 1979 930- 3.4L Andial Racing P/C's/Fuel Enrichment System/Adjustable Boost Control,Euro Fuel System,Group B Cams,K27 Turbo(1.0 Bar) Andial Intercooler, GHL Muffler/SS Header Sys,Welt. SS Kit/Camber Brace, SS Brake Lines, 350mm Momo, Billet Pedals, 9x17 - 11x17 Fikse. 1999 FXSTC- Harley Davidson HI-4 Ignition,Thunderball Cam,Mikuni 42mm,Vance & Hines 2003 Jetta Wagon GLS 1.9L TDI 1993 GMC Jimmy 4x4 St. Louis PCA - Member Kirkwood H.O.G. Chapter #2573 - Member Gateway H.O.G Chapter #1337 - Charter Member |
Information Junky
check your PM.
Everyone you meet knows something you don't. - - - and a whole bunch of crap that is wrong. Disclaimer: the above was 2¢ worth. More information is available as my professional opinion, which is provided for an exorbitant fee.
Super Moderator
Yeah I tried the emissions goo, ran alcohol through it, all that good stuff... My baby just don't wanna run lean...
![]() I was offered use of a cat for my car, I think it's time to start lossening my exhaust bolts...
you can create an air pump by plugging an injector line. find a plug with the same threads as the banjo bolt that holds the line to the fuel distributor. one cylinder is now an air pump, and the emissions will go down quite a bit. yes it will be running on 5 cylinders. so what?
mannkar
John Walker's suggestion works..... I was helped through emissions in a similar way. I was given a fuel injector with the end brazed shut. I swapped the fuel injector on #6 just before I went through the test station.....passed emissions, then swapped back on the other side.
