Amac's Avatar
Tial Wastegate
Want to buy a Tial, where is the best place?
Is $528.00 the going price for a 46mm ?
Someone hook a junkie up!!!!
"Never go faster than you can stop"
85 - 930 (750hp)
Norwood motec 3.5 twin turbo
Old 11-04-2002, 10:40 AM
beepbeep's Avatar
Why do you need Tial?
I bought used 930 wastegate in really good condition from a Pelican-member for 250$. (OEM 930 wastegate flows enough to support 500+ hp engines).
Thank you for your time,
Old 11-04-2002, 10:57 AM
juan ruiz's Avatar
Dear Fellow Junkie thats about correct on the $ and since you are a active menber of the HP Junkies we are happy to supply you with the needed information.
http://www.tialsport.com/
10.76@139-1/4 mile
0-1 mile 193MPH
I Love to Shine Cars
Old 11-04-2002, 11:02 AM
Amac's Avatar
Hey beep,
Your right, the stock wastegate is a good unit.
The stock wastegate tends to leak pressure
before opening. The tial slams open at your
max boost setting, no leaking.
I run 2 Tial's on my other car.
Plus they look cool!
Stay cool on the dark side!!!!
85 - 930 (750hp)
Old 11-06-2002, 08:48 AM
beepbeep's Avatar
No offend, but i think you got indoctrinated by ricer marketing.
Wastegate is wastegate, it operates with a spring. Tial has a spring and a piston just as OEM wastegate. When boost is high enough, membrane pulls up the piston and wastegate opens.
Wastegate creep occurs in Tial wastegate as much as in OEM, it's up to external boost controller to prevent creep. External controller doesn't let boost enter the wastegate until it reaches pre-defined level, and then it starts pulsing it on-off so boost is sustained.
Maybe two "bling" wastegates look cool but they are just extra weight to me.
Cheers!
Old 11-06-2002, 09:56 AM
I have heard about wastegate creep for years. I think it is a bunch of bull. I tested my 930 wastegate. No creep at all. Maybe some do but I don't buy it.
Dean
911 SC turbo, 3.0L 930 motor, G50, 930 brakes, DTA EFI, 352 RWHP DynoDynamic dyno,
Old 11-06-2002, 03:27 PM
Amac's Avatar
Blown,
How did you test you wastegate?
The 930 wastegate design is 30
years old. I've owned both stock
and Tial wastegates, the Tial is a
better unit.
I'm not trying to sell wastegates,
but I do tend to follow the performance
engin builders and tuners.
85 - 930 (750hp)
Old 11-07-2002, 11:54 AM
beepbeep's Avatar
Yes, 930 wastegate is 30 years old but it's such a basic piece of equipment that nothing changed during those 30 years.
It's just a valve for gods sake, there are not many ways to build one. Spring, membrane, piston, mating surface = that's it! Tial looks just the same but has that "hella sweet" eloxed aluminium look on it's wastegate bell. As long as it's spring is as hard as OEM 930, it will start creeping as soon (or late) as OEM.
I'm not trying to say that everyone should use OEM, but it's like changing water-tap saying "it's 30 yr old, therefore it probably leaks water and i need that shiny new one". It's still just a tap. If seals are OK it will work...
And for second time:
You can eliminate wastegate-creep by using electronic boost-controller that doesn't supply pressurized air to wastegate-bell until pre-defined pressure is achieved which keeps it shut.
Old 11-07-2002, 12:24 PM
Amac's Avatar
beep,
I have all the tricks in my bag when it comes to P cars.
I've either put it on, taken it off, or broke it.
Computer controll boost I have, it's not going save
the OEM from hitting the floor.
Maybe some day you'll try one.
Life's short, drive hard.
85 - 930 (750hp)
Old 11-07-2002, 03:02 PM
Amac,
I tested my wastegate with a regulator and a gauge when I had the unit off the car.
Dean
Old 11-07-2002, 05:00 PM
WydRyd's Avatar
I have a TiAL unit in my car, hooked up to an Apexi AVC-R EBC.
A very high quality unit and much lighter than an OEM 930 unit.
Unless you have a faulty OEM unit, no need to go aftermarket. I only went TiAL cause my setup is aftermarket, not factory turbo.
If you can get a good OEM unit for half the price of a TiAL, go down that route and put the left-over funds towards an EBC. You won't look back
Merv
'89 911 Turbo Cab
Protomotive MAP ECU, Twin Plugged Heads, GT2-EVO CAMs, 3.3L fully finned P&C's, ARP fasteners, C2T head gaskets, Titanium Retainers, Turbo spec valves, springs & guides, 964 splash valves, GT35R BB turbo, GSF Stainless Headers, Magnaflow Exhaust, Full bay Intercooler, TiAL 46mm w/gate, TiAL 50mm BOV, Apexi AVC-R EBC, SPEC Stage3+ Clutch kit, Crane CDI Ignition
Old 11-08-2002, 03:16 PM
