Coil overs to replace broke torsion tube s
I have a 69t and my torsion tube broke. Can I easily convert to coil overs ? Which ones ? How ? Thanks for any advice.
Old 06-07-2015, 06:41 PM
I would rather be driving
jpnovak's Avatar
TEchnically yes but its not a good idea. The transmission mounts to the torsion tube and it is a significant structural member of the car.
Get a new one welded in. The common method is to splice, butt weld and seam the new torsion tube but this will depend on where its rusty.
I would also suspect you have other rust that might be needing attention if the torsion tube is broken.
Old 06-07-2015, 06:51 PM
I fixed the "other" rust, then the tube broke. My son suggests I weld it up , then go coil over, because the torsion bars won't fit right. I think he's right . Is he ?
Old 06-07-2015, 07:02 PM
pors1968's Avatar
Any pict of broken tube .Where is broken.
Old 06-08-2015, 05:56 AM
A friend of mine did just that when his torsion tube broke. Keep in mind that there is a bit of structural work that needs to be done when doing this conversion. You'll need to talk to someone at a race shop. Sprint car builders are your go-to guys for modifications such as these.
Christopher Mahalick
1984 911 Targa, 1974 Lotus Europa TCS
2001 BMW 530i(5spd!), Ducati 900 SS/SP
2006 Kawasaki Ninja 250, 2015 Yamaha R3
1965 Suzuki k15 Hillbilly, 1975 Suzuki GT750
Old 06-08-2015, 06:02 AM
Not only the Transmission but also the Trailing Arms mount onto the tube and unless well located will cause serious handling problems.
Also with a 1969 car you would have to fit the shocks upside down and use an adapter for the eye end as the shock tower is very small and a suitable coil spring wouldn't fit if was mounted the correct way up.
Volume 11 of the Workshop Manual shows how to replace the tube.
Old 06-08-2015, 07:19 AM
