Rennch on YouTube
Replaced Master Cylinder, new switch only has 1 terminal
Today I replaced my master cylinder, but my old cylinder has spots for two terminals and the new one only has one. any thoughts on what I should do? I saw a suggestion to leave it off, but I would like to know where it supposed to go.
Michael O'Neal - 69 RSR Clone(ish) - The build: http://bit.ly/69porschersr 69 911S Blasphemy Build on YouTube Rennch Youtube Channel: http://rennch.com/Youtube Instagram: https://www.instagram.com/_rennch_/ |
Member 911 Anonymous
Do you mean the brake light switch terminal connectors?
Please post a pic
'85 Carrera Targa Factory Marble Grey/Black * Turbo Tail * 930 Steering Wheel* Sport Seats * 17" Fuchs (r) * 3.4 * 964 Cams * 915 * LSD * Factory SS * Turbo Tie Rods * Bilsteins * Euro Pre-Muff * SW Chip on 4K DME * NGK * Sienes GSK * Targa Body Brace PCA/POC |
Rennch on YouTube
This one. My original has two spade connectors, and the replacement has one.
![]() Sent from my iPhone using Tapatalk
Call PP and see if you ordered the correct one?
Your thread title refers to 1 terminal on the switch, but your post refers to the number of switches in the master cylinder. My '87 master cyl has spots for 2 switches, and each switch has 2 terminals. I don't know enough about your year or the suggestion about leaving something off.
Dan '87 Targa Carrera 3.2 - Fabspeed Cat Bypass, M&K Muffler, SW Chip Venetian Blue Last edited by steely; 06-08-2015 at 06:56 AM.. |
That is the wrong type of brake light switch. The one in the picture has a mechanical plunger (black object) which is activated by hydraulic pressure and makes an internal connection to the spade connector. It is typically found on early Mercedes and is also used as a switch for tripping the cruise control when the brake is depressed.
You need a two spade switch as mentioned in earlier posts.
L.J. Recovering Porsche-holic Gave up trying to stay clean Stabilized on a Pelican I.V. drip |
Rennch on YouTube
This was the option from pelican. No worries, thanks for the help.
